The Best tube/valve sound!?
tinitus:
If you feed a single HT supply through a bifilar choke to two loads then you have two choices:
1. currents aiding, so get core saturation and little or no choke action,
2. currents cancelling, so good choke action so any noise generated in one load gets transferred across to the other load.
Which of these were you thinking of?
PS posts coincided, but my point stillstands
my version of brosike CCDA, took me about 4hours to complete...😀
Hi Tony!
By all that you're doing this pre-amplifier?
How does it sound?
i probably built around 2 dozens of these.....i have lots of friends who liked this line amp.....this is the latest version, 2 sets of inputs 1 set of outputs......this line amp seems to tolerate a lot of tube types, like the 6BK7, 6BQ7's....etc....
how it sounds? very satisfying......😀 and very quiet too, no hums, no hiss....
Hi
I'll make another power supply with LM317 and MJE340 and other components. With these power supply reduce noise to a minimum.
Will present these days schematic for power supply.
the key here is to bias the filaments with dc voltage anywhere from 1/4 B+ and higher.....i have resisted the use of voltage regulators, i use massive capacitor filtering instead...😀
