900W H-class PA Amp with Limiter
hi apex sir,
is this correct sir h900 tef?
My APEX H900 Ver.2
I would like to build APEX H900 Ver.2
Thank you Mr. Mile for sharing this class H amp...
Wiljj78
HELLO
Driver stage on H900 work with +/-120V DC, only output stage work with /-60V DC and step to +/-120V DC in peaks.
Hi Apexaudio
greetings my mistake can output stage be modified to 70 - 75
volts dc want to try with TEF its still my favourite amp 😀
warm regards
andrew lebon
Oops.. my bad..I just happened to push the drivers with a bit more bass and the coils got toasted..😱. I also forgot that my traffo was over sized and did not use apex protect 😱.
Apexaudio or Andrew T or someone could please add a 50Hz low cut filter to the Amp input please .. It can be a little upgrade to the amp..
Nice work, I suggest to warm up TIP31C to test high speed fan and thernal protect, also you can connect AC to PRO input and test overload protect (must be power off reset).
I've tried to use Solder TIP31C transistor to heat and measure the voltage coming out in the Fan and the result output Voltage grow up, but I have not found a way to determine the point of PRO (Short Protection) to work without having to use the Power Amp.
regards
Nice design sir.... 😉
Would u shared me with sprint layout ver.?
Thanks n regards...
Hello Rizqi,
Thanks.. This design have not been tested yet i'm still trying to find some error before i etch, but you can also review and let me know if you found any mistake so i can correct the error.
Send me your email add so i can forward you the sprint layout file.
