Ian FIFO KIT group buy GB III is running now
Description
Here is the R&D thread which you could find all the details.
http://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter.html
But for many of us, thread is too long to follow up, so alternatively you can download the user’s guidance and other technical documents I attached below as a kind of sum up.
I’m trying to keep all the pricing as same as GB I and GBII, but may have more items listed.
I may not include the XLR socket on the S/PDIF board for this time for it is too big to ship in an envelope which can save some on shipping for you.
Another thing is the 3.9% Paypel fee was too much for me. I’m afraid I have to ask you kindly sharing half of the Paypel fee with me which would be 1.95% of the total payment as same as GBII.
All of the Digikey part numbers of the accessories were given in the corresponding technical documents. You can buy them from Digikey directly.
Lists and prices
1. I2S FIFO KIT V3.80 $149- USD/ea
Including:
- A finished and tested I2S FIFO Board with firmware V3.80 upgraded
- Two 8" single-ended PH 2.0mm 7-pin I2S cables
- One 2" double-ended PH 2.0 mm 7-pin I2S bridge cable
- One 6" double-ended U.FL cable for MCLK
- One 2" 10-pin FPC/FFC cable
- An 11.2896 MHz oscillator installed for function verification
- An universal SMT XO adapter KIT for free
- A BIII adapters PCB (input adapter and sync/async clock adapter) for free
- A jumper KIT for free
2. Dual XO Clock board V3.3 $59- USD/ea
Including:
- An assembled and tested Dual XO Clock Board (double-sided SMT mounting)
- One 6” double-ended U.FL coaxial cable
- One 2” 10-pin FPC/FFC cable
- 22.5792 MHz and 24.5760 MHz oscillators for function verification
3.S/PDIF Interface Board $89- USD/ea
Including:
- An assembled and tested S/PDIF Interface Board
- Two 5” double-ended PH 2.0mm 7-pin I2S cables
- One 6” double-ended U.FL coaxial cable for MCLK output
- One 2” 10-pin FPC/FFC cable to interface with the I2S FIFO Board
- Two BNC to RCA adapters
4. U.FL coaxial cable connection accessories
SMT U.FL socket $1 USD/ea
4” double-ended 50 ohm coaxial cable $2 USD/ea
6” double-ended 50 ohm coaxial cable $3 USD/ea
12” double-ended 50 ohm coaxial cable $4 USD/ea
5. I2S backdoor KIT for S/PDIF board $3.99 USD/ea
Including:
- A 4 pin PH2.0mm SMT male connector
- A 4 pin PH2.0mm connector house
- Four 8” single-ended cables with PH2.0mm terminal (same or different color)
- A small piece of high temperature SMT tape
6. Package of Universal SMT XO Adapters lot of 5 $9.99 USD/ea
Including:
- Five Universal SMT XO Adapter PCBs (linked together with V-cut)
- Twenty pin terminals
- Ten 100n 0603 SMT MMLC for the optional decoupling capacitors
- Five 1u 0805 SMT MMLC for the optional decoupling capacitors
7. Additional BIII adapters PCB $3.99 USD/ea
Including:
- A input U.FL adapter PCB
- A SYNC/ASYNC clock adapter PCB
8. SMT connector package for BIII adapters $3.99 USD/ea
Including:
- A 20 pin 2.54mm SMT female connector header
- A 3 pin 2.54mm right angled pin connector
9. FIFO isolator board V1.5 MINI KIT $15.99 USD/ea
Including:
- An isolator PCB
- Two 7P Ph2.0 cables
-Two 10P FFC cables
-Two 7P Ph2.0 SMT sockets
-Two 10P FFC SMT sockets
-One 2P Ph2.0 power cable
-Four 33ohm SMT resistor array
10. 10P 1.0mm FFC/FPC cables combo $3.99 USD/( three cables)
Including:
- Three 7P 1.0mm FFC/FPC cables, 2”,4” and 6”
11. Battery management PCB free
For free, limited one per order. 20 in stock. Have to put a comment on the order form if you need.
Terms and conditions
- All finished PCBs are factory assembled by Pb free SMT processing
- Loop tested and bit perfect confirmed
- Technical support by email or via DiyAudio thread
- Repairing for free within 1 year from purchase, buyers pay any possible shipping and parts
- I provide firmware upgrading service for free within 1 year from purchase, buyers pay any possible shipping
- No return as DIY KIT
Selection guide
1.If you just stick with one Fs I2S source and do not change it often, for example, 44.1 KHz I2S from a CD player, then the I2S FIFO KIT is working for you without any problem. You don’t need other two boards. With both 256*Fs and 512*Fs default MCLK frequency available,FIFO FW V3.80 provides more options for this selection. One XO frequency can run two Fs, and one Fs can use two XO frequencies.
2.If you Fs will change often or album by album, for example, I2S from a USB, then you will need the Dual XO Clock Board working together with the FIFO.
3.If you need including the S/PDIF input and output functions or you want to setup a S/PDIF FIFO, or you need switching input between S/PDIF sources and optional I2S source, then the S/PDIF Interface Board would be your choice.
4.With the FIFO FW V3.80 and the I2S backdoor KIT, you can include an additional I2S input source from the S/PDIF Interface Board.
5.Isolator board is highly recommended for your DAC to make clock board as a DAC local analog section with isolated from all other digital frontend.
Delivery and shipping
Delivery via Canada Post. Will be in one of the three following types:
Less than 100g: in a letter, no tracking number
Less than 500g: in a bubbled envelope with/without tracking number
Above 500g: in a box with/without tracking number
Pleas put correct shipping address on your order form and let me know if you need a tracking number, I’ll decide the type of shipping to make a maxima saving for you.
Please understand I don’t responsible for lost mail. So with a tracking number is recommended. I’ll list the roughly postage below for reference:
To Canada:
In a letter without tracking#: $1.5
In an envelope without tracking #: $4.5
In an envelope with tracking #: $12-
In an box with tracking#:$17-
To USA:
In a letter without tracking#: $2.5
In an envelope without tracking #: $8-
In an box without tracking#:$12-
In an box with tracking#:$21-
To international:
In a letter without tracking#: $4.5
In an envelope without tracking #: $15-
In an envelope with tracking #: $29-
In an box without tracking#:$21-
In an box with tracking#:$68-
To save time, I will not ask for or return the actual shipping difference within $5.
How to buy
1.First, please confirm you have already registered here on the waiting list. Make sure your order number is correct (“GBIII”+waiting list number, eg GBIII23)
2.Then, to keep your privacy, please download the empty GBIII order form (GB3OrderformEmpty.zip, excel format, pdf format just for reference) at bottom of this post, full in all the necessary information in blue section by excel, rename the file name staring by your order number on the waiting list and following by your Diyaudio ID(for example GBIII23_iancanada.xls), send the finished excel order form file back to my email box: iancanada.mail@gmail.com
Following informations are required in the order form:
- Your diyAudio ID
- Your PayPal account (usually an email address)
- Your email (if it is possible, use the same email as Paypal)
- Items and quantity you want to buy
- Shipping address (if it is possible, use the same as Paypal)
Please double check and make sure the shipping address is correct and with a postcode, otherwise it may result in losing of the KIT.
3. Once the items are ready for delivery, you will receive a conformed invoice based on your order from my email box with my PayPal account.
4. Making payment. (PayPal only)
5. KIT will be shipped within 7 days after I’m getting the payment.
6. Give me a feedback to iancanada.mail@gmail.com after you get the KIT.
I ordered more than 50 KITs for GB III, so it seems I have enough to supply this time. So now, the GB III is still open. New registers are still welcome. But I’m afraid I have to close it one week before delivery or I run out of the KIT.
Again, I’m very pleased having opportunity sharing the FIFO KIT with the diyAudio community. Enjoy you amazing project!
Ian
Please note:
1. Please download the now order form and send it back to me at iancanada.mail@gmail.com even if you already sent the old form.
2. Your order number will be “GBIII” + waiting list number. For example, if you are N23 on the list, your order number will be GBIII23. Please include this number for anything.
3. If your Paypal shipping address is different from the one on your order form, I’ll ship to the Paypal address except you put a note with new address on your Paypal payment form.
4. If you know your address use to have problems such as customs clearance or lost mails or etc, please give me a safe address in Canada or USA to ship to.
5. For CanadaPost, tracking number equal to register, no tracking number means it’s not a registered mail.
Description
Lists and prices
Including:
Including:
Including:
Including:
Including:
Including:
Including:
Including:
- An isolator PCB
-Two 10P FFC cables
Including:
Selection guide
To Canada:
To USA:
To international:
How to buy
- Your diyAudio ID
Ian
Pictures of Ian FIFO GBIII items
Pictures of Ian FIFO GBIII items.
Originally Posted by JamesHill View Post
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 2x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x battery management boards, 4x Isolator board kit
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 1x I2S backdoor KIT, 1x Package of Universal SMT XO Adapters, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x battery management board, 1x isolator board, 1x Si570 clock board
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 3 x battery management board
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 1x isolator board kit , 1 x battery management board
N18 Tagheuer 2x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm, 1x isolator board kit , 1 x battery management board
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT for S/PDIF board, 1x Isolator board kit, 1x battery management kit
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT, 6 x 4" Cables, 6 x 6" Cables, 1 x Dual clock board, 1x S/PDIF Interface, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters, 1 x SMT connector package for BIII adapters.
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x Universal SMT XO
Adapters KIT, 8 x 4" coax cables, 1X Isolator board kit, 2X battery management boards
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 2 x Universal SMT XO Adapters KIT, 8 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT, 4 X battery management boards
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables, 1 x isolator board kit, 2 x battery management board
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 20 x SMT U.FL Socket, 8 x 4" coaxial cable 50ohm, 8 x 6" coaxial cable 50ohm, 8 x 12" coaxial cable 50ohm
N30 andrea_mori 3 x I2S FIFO, 5 x isolator board kit
N31 acko 1x I2S FIFO Kit, 1x Dual XO Clock Board
N32 vitalica 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board ,20 x SMT U.FL Socket, 12 x 4" coaxial cable 50ohm, 12 x 6" coaxial cable 50ohm, 12 x 12" coaxial cable 50ohm;4 x isolator board kit and 4 x battery management board.
33 TV Man 2 x i2s FIFO kit, 2x Dual XO Clock Board - Need other parts too, ie. sockets and cables, but have to sort out which ones.
N34 supra 1xI2S FIFO kit, 1x Dual XO Clock board
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board, 1x Isolator board kit, 1x battery management kit
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4” double-ended 50 ohm coaxial cable
N37 AR2 1x isolator board kit and 1 x battery management board
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4” double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
N39 NicMac 20 x battery management boards
N40 leejh 1*I2S FIFO KIT, 1*Dual XO Clock board , 1 x BIII adapter, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x SMT U.FL Socket, 2 x 4" coaxial cable 50ohm, 1 x 6" coaxial cable 50ohm, 1x isolator board kit and 3 x battery management board
N41 necplusultra 1*I2S FIFO KIT,2 x battery management boards
N42 ruupie 1*I2S FIFO KIT, 1*Dual XO Clock board , 2x isolator board kit and 3 x battery management board
N43 crazikid 1x I2S FIFO Kit, 1x Dual XO Clock Board
N44 Odysseas 1xI2S FIFO KIT,2xDual XO Clock board, 1xS/PDIF Interface Board, 2xU.FL coaxial cable connection accessories, 1xI2S backdoor KIT for S/PDIF board, 1xPackage of Universal SMT XO Adapters, 1xAdditional BIII adapters PCB, 1xSMT connector package for BIII adapters, 4xTI boards(if possible), 4xbattery management boards(if possible),1xisolator board
N45 Slartibartfasst 2x battery management board, 2x isolator board
N46 Greg Stewart 1 x isolator board mini kit
N47 DUC985 1xI2S FIFO KIT,1xDual XO Clock board
N48 crobbins5421 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x isolator board kit
N49 MisterRogers 1x I2S FIFO Kit, 2x Dual XO Clock Board, 2x isolator board kit, 2x BIII adaptors 12x 6" U.FL
N50 lwif 1 x isolator board kit, 2 x battery management board ( or more if available)
N51 atom6422 1 x isolator board kit, 2 x battery management board
N52 JamesHill1 x isolator board kit, 1 x battery management board
N53 deanoUK 1x I2S FIFO Kit, 1x Dual XO Clock Board, 26 X SMT U.FL socket, 1 X Package of Universal SMT XO Adapters, 10 x 4” coaxial, 2 x 6” coaxial, 1 x 12” coaxial, 4 X Additional BIII adapters PCB, 5 X SMT connector package for BIII adapters,1 x isolator Board
N54 mravinsky 1x isolator board kit, 5 x battery management board, 8 x 4” double-ended 50 ohm coaxial cable, 4 x 6” double-ended 50 ohm coaxial cable, 10 x SMT U.FL Socket
N55 Popolvar 1 x I2S FIFO KIT, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 2 x battery management boards,1 x isolator board
N56 qusp 4 x 4” double-ended 50 ohm coaxial cable $2 USD/ea, 1 x backdoor kit, 1 x isolator kit
N57 nvduybom 1x I2S FIFO KIT V3.80 $149- USD/ea, 1x Dual XO Clock board V3.3 $59- USD/ea, 1x S/PDIF Interface Board $89- USD/ea, 1x Additional BIII adapters PCB $3.99 USD/ea, 1x MT connector package for BIII adapters $3.99 USD/ea, 1x Battery management PCB free
N17. Finaxe 1x I2S FIFO Kit, 2x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 1 x battery management board
I added some items.
I added some items.
Ian FIFO GBIII
nvduybom,
Did you used that form for your order? (Look at the post #761 to know how to proceed)
GBIIIOrderFormEmpty.zip
nvduybom,
nvduybom,
Thanks finaxe,
I complete order via email with this form and waiting confirm for payment .
Order form received:
09,11,12,17,18,19,20,25,27,28,30,35,36,37,38,40,42,44,46,47,48,49,52,55.
Please let me know if I didn't receive your order form.
Ian
Ian
Ian
You not receive my mail 🙁 ?, I just retry mail for order (N57_nvduybom) .
nvduybom
Thank you for your order. Got it 🙂.
Ian
Ian,
I (N39) just would like 20 battery management boards. Any way for me to get these? I will be happy to wait so please let me know if you will place another order for these.
Nic
Nic
Ian
I sent you on August 17h the GBII order form...
Ian,
Nic
Thanks Nic, But I'm afraid I dont have that much this time. Please wait for next GB for more battery PCBs. Sorry about that.
Ian
Order form received so far Nov27:
09,11,12,17,18,19,20,21,25,26,27,28,30,32,35,36,37,38,40,42,44,46,47,48,49,52,53,55,57.
Please let me know if I didn't get your order form.
Thanks,
Ian
Thanks,
Ian
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
