F4 power amplifier
5W=U^2/50R
5W x 50R=U^2
(5W x 50R)^1/2=U
=15V8 RMS = 44V7p-p
what means that you need even slightly higher rails for that F4
30db gain means (30/20)inv-log = around 31 x
so , with 2 in , you'll get 62 out ........ if stage is not clipping before that
using balanced will double possible swing , but gain remains the same
Dear zen mod
Another stupid question, do you ever measure Your P1 ?
What is different between B1, B2 and B3 ?
Which one better go for double F4 or F4 with B1/2/3 ?
For 87 db speaker
thank you, best regards
clarify
you mean on First Watt B1, B2 , B3 ?
how big P1 in your amp?
the question is
- can b1/b2/b3 increase gain on F4 to drive 87 db speaker ?
- or better to use double F4 / use 4 pcb to drive 87 db speaker ?
- which b1/2/3 better for f4 ?
thank you Zen
the question is
thank you Zen
my F4 ( Papa's Koan ) is plain F4 made by R1 schematic , so P1 is 5K
for F4 , of all B's , only B3 is adequate
but - observe what's written on B3 page : http://tinyurl.com/d34lzku
for your spks ( some other things are also important , besides db/W - room size , your listening habits ...... ) safe bet is using F4 as balanced ....
lacking B3 , best thing for now is combining BA3 Balanced front end with input buffer-less balanced F4 ......... and that combo is simply BA3 amp , balanced
for my spks (94db/W/m , 16R ) I'm feeding F4 as SE , ditto from DAC output and I'm having max 600mW as result
still lacking some 6db of voltage swing for full blast , but I'm lazy bstrd :clown:
hi zen
i got aleph p 1.7 setting on the highest output ( 1-0-0-1 )
and the X2 preamp, it is enough to feed F4 ?
i was interest with glassware audio like pjgregory did on the post #3179
but after i think view times got an original product maybe better for me
i will think about B3 front end on the next step
now making chassis for the F4, walter burkhard give me a lot of homework
to make a beautiful chassis ( i bought heatsink from him )
Pumpkin is, of course ........ :Pumpkin:
but , there are few reasons why I'm not mention it :
-I'm still Paypal-less , and tired of inventing new ways to have it ,
-I hate advertising in every possible place
Pocoyo - X2 is wonderful little gadget , but not optimized for output swing needed for balanced F4
X2's output stage is having ~ 10mA Iq , not enough for your purpose ( at least in my book ) while changing/tweaking that is almost impossible , considering it's physical layout
make full BA3 , balanced and use X2 to drive it
Yes Sir ... Allright Sir !
I will search the BA-3 green PCB
BTW can i connect the BA-3 supply
from F4 PSU ?
