any kits/flat packs offered on these? They would look good in my office.
These?
http://www.diyaudio.com/forums/planet-10-hifi/211413-ufonkenset-solid-cedar-flat-pak-prototypes.html
Zia has linked to the thread.
More pictures:
http://www.diyaudio.com/forums/plan...en-fonken-picture-gallery-14.html#post3106523
The pics are of the alpha build (Scottmoose also have a pair, as yet unbuilt) which i am thourougly enjoying.
I am just shipping the last of the betas and building a pair myself ... if i can build a pair anyone should be able too.
If you want to see my progress, early work on the docs here:
Cedar uFonken assembly
Beta builds are showing some adjustments required, when Bernie has some time, there will be official flat-paks of these. Each pair will be unique, andi look forward to seeing how people will finish them.
I have only breifly touched on flat-paks in plywood for these, but once Bernie has the cedar ones sorted, and we know what jigs work, we may do some if there is demand.
dave
Tanken 1808 and Fonken FF125WK both by Dave
Here's some more photos.
In the first photo I still had the driver masked off for finishing. It is not some kind of amazing grille cover for the speakers... I had to do this because I ended up with such a tight friction fit that I cannot get the drivers out! Totally a mistake on my part. I think my jasper jig must have shifted slightly towards the pin setting for this cut out and so shaved a tiny bit of DIA from the hole. I'll have to be more careful next time.
I had them running with a TA2024 from Ebay, VERY happy with the sound.
KM
KM
!st set of uFonkebSET done from the get go with matching woofT
This looks like what I need in my living room to replace my ProAc 150s
Are you going to offer this design as a flat pak?
Congrats Kyle, nice job indeed.
Any difference you find in the sound vs a standard MarKel-70 (which also sounds great)?
Thanks!
The sound is very similar. They have a very satisfying low end.
KM
- More Vendors...
- Planet 10 hifi
- miniOnken/Fonken Picture Gallery
