900W H-class PA Amp with Limiter
measure the voltage across that 5W 47R resistor and than calculate power disipated on it by the formula P=R x I^2. if the power calculated is larger than 2W than you should use 7W resistor.
power disipated by 7812 is also easy calculated by measuring voltage between in/out pinouts and multiplying it with current flowing through it. if the power calculated is smaller than suggested by manufacturer than just add a heatsink on it.
what voltage is at relay coil?
what is main supply voltage?
Coil Relay 24VDC
IC 7912 and resistor 47R/5W are used for fan suply... post pictures with botom side of your pcb.
Sir MILE, Here Layout PCB Protect
i was commenting from bus on my way home and did not have schematics to see so i thought that it supplies the relay coil. anyway,power disipated by 5W resistor and voltage regulator is to be calculated as i said and than decide will you replace the resistor and put the heatsink od voltage regulator,wich i would anyway. greetings!
OK, thanks for the advice. I hope Mr. APEX can provide input for this. problems in R 5 Watt and IC 7912 are very hot.
Hello Mile sir,
Having built B500 I m impressed by the performance of the amp. The next step is to get the most juice out of my 2.5kva toroid and 2kw speakers.. I have gone through this thread and finally decided to built H900. What I couldn't find is H900 schematic with 8pairs of output transistors to support 2ohms and 16 ohm loads. Maybe I have missed it. So I am looking for H900 triple emitter follower schematic/circuit . I request Mile sir or diy members to please help me with H900 tef circuit. Thank you 🙂
