DAC-END The best DAC AD1865- UPDAT 2011
Yeah, sure. Mine is attached.
There are some missing parts because I've already have them in the parts bin so I just left them out from the BOM.
Also, I overspec'd some caps, increased the quantity of some easy-to-fail (2sk170, bc550, bc560, mje350, irf9510...) parts to have some backups in case something goes wrong during the build.
I attach my BOM, all parts except for the case, from Mouser, Parts Connexion and eBay.
A few questions:
- did you mount SPDIF transformer?
- about IV HV: are you using centre tapped 260-0-260 and 2 rectifiers only or single 0-260 and 4 rectifiers?
Hi all,
I'll use 5687 and E182CC tube, so I have the following questions:
- filament: linking J1 seems the heaters are powered wih 12.6V, so what secondaries of R80-36 transformer should I use? more simple, what colours?
- anode: using 4 rectifiers and R80-36 transformer, what secondaries should I use 0-230 or 0-260? in parallel? more simple, what colours?
Andrea
Hi all,
Andrea
hi!
if use 5687 or e182cc use 12Vac for filament
use 0-220Vac for shunt!
Hi all!
To day i have some PCB IV LL1660 , if you like please sen to me pm!
Problem with the power stage circuit
Hi Quanghao, I have a problem with the power stage circuit in the 260V SSHV specifically, since there is only the 61V output.
I have attached some pictures where you can see the component values ​​that have been used and the voltages obtained.
Thanks.
