Guys - as much as I like the idea of everybody ordering something he has no idea of what it really is 🙄 - perhaps it is a little bit early for that. I am sure we will have a proper order sheet set up when we know what we are talking about.
Dear Holger,
until everything is said and done, this is just a chance
to see what level the interrest of builders reaches.
No one of the subscribers will be forced to buy anything
they allready do not know about.
And i do think this much is crystal clear for everybody,
allmost...😉
allmost...😉
Dear Peter
If you will start with GB, dead sure a set for me. You need a hand ??
Give me a shout!!!
Werner
Give me a shout!!!
Werner
Hi Peter
Will be there together with friends around two pm Saturday
For details I send you a PM or give you a call.
Take it easy
Werner
Take it easy
Werner
Here is the basic schematic diagram of the Paradise Pre Regulator.
You can see the correct use of common mode chokes and ripple reducer coils ( me thinks ).
The common mode coils are rather small in physical size. They are optimized to remove HF/RF noise.
The filter chokes are much bigger in size and work in the audio band by reducing ripple on the DC power line. They form a pi filter with the 10.000uF caps. This chokes have quite a high DC resistance so they burn some voltage. For a current draw of 200mA they drop 8V. That is the reason i chose a main transformer with quite high voltage, in this case a Hammond 2 x 28V model. Other transformers can be used. I prefer Block split bobbin, others may like RCore although i heard that the cheep ones from france ( made in india ? ) are not that good.
There is a wide choice for the diodes too. UF4004 is good enough i think but maybe the crowd likes ultra fast, soft recovery diodes in TO220 cases. I will use Panasonic THS elcaps. Others may like F&T, RIFA, Mundorf etc.
Hello Joachim,
I have already transformators,
2 x 24 V 20 VA
Can I use them without any changes?
Thanks,
Christoph
2 x 24 V 20 VA
Thanks,
Christoph
Great, but calling it a pre-regulator is kinda misleading, isn't it?
2 x 24V may work but the Hammond chokes drop a lot of voltage.
There are other Hammond chokes that drop less so i have to search one for you that works.
This Pre-Regulator has some regulation although passive so why not calling it a Pre-Regulator ? The main regulators are on board, the shunts.
That would be nice, glad to hear I have not to buy them twice.
Do you know about the size of the pcb's?
Thank you,
Christoph
- Group Buys
- Paradise Phono Preregulator
