Paradise Phono Preregulator
Dear Holger,
until everything is said and done, this is just a chance
to see what level the interrest of builders reaches.
No one of the subscribers will be forced to buy anything
they allready do not know about.
And i do think this much is crystal clear for everybody,
allmost...;)
Here is the basic schematic diagram of the Paradise Pre Regulator.
You can see the correct use of common mode chokes and ripple reducer coils ( me thinks ).
The common mode coils are rather small in physical size. They are optimized to remove HF/RF noise.
The filter chokes are much bigger in size and work in the audio band by reducing ripple on the DC power line. They form a pi filter with the 10.000uF caps. This chokes have quite a high DC resistance so they burn some voltage. For a current draw of 200mA they drop 8V. That is the reason i chose a main transformer with quite high voltage, in this case a Hammond 2 x 28V model. Other transformers can be used. I prefer Block split bobbin, others may like RCore although i heard that the cheep ones from france ( made in india ? ) are not that good.
There is a wide choice for the diodes too. UF4004 is good enough i think but maybe the crowd likes ultra fast, soft recovery diodes in TO220 cases. I will use Panasonic THS elcaps. Others may like F&T, RIFA, Mundorf etc.
  • Paradise Pre-Regulator.pdf
