Cheap simple class D amp circuit to build.
hi all another cheap solution to go about it . thanks to detex audio
  • detex 100wts amp.zip
  • NegativePCB.pdf
    NegativePCB.pdf
i heard a lot of posts around the detex amp,but i may never know if it works,i am very curious.
i have heard about 70a mosfets at 100v with 14 miliohms which should be suitable since they are complementary ones,this way operation in 2 or 1 ohms is possible.
i am looking to build it with smps for 45v
Some Problems after 60% volume
Hello everyone,
I just made this class D pcb, and it's work, but until 60% of input volume. After that the sound is very bad, and on scope the pwm dissapear. Distorsions are very high. I tried all kind of core including t106-26 and t106-2 (red one from micormetal), at 35uH, and same result. I used LM393 N. Vere is the problem?
+-35 volt, Rss 500R/1w, zenners at 1W, and I switch irf540/9540 with irf640/irf9640 with same result.
Maybe LM393 N is resposible for that. Should I use LM393AP witch is faster???
Same problem
Hello everyone,
Anyone, any sugestions? I swith to LM393AP(faster than lm393n) with same result. Amp work very well until 60% input, and after that, the speaker cracking. I cant identify the problem.
Here's the scope video...https://www.dropbox.com/s/0ve1bfuajom50ps/VIDEO0016.mp4?dl=0
