Not sure whats happening. I have spend many hours ..days going over eveything still no voltgage. I added a 3.3 k to R 4 thinking that may be it. Could the mosfets be bad. or did I not measure correctly. Thanks, Allan
I just checked Q3 & Q4 and they look correct...except I mixed the matched pair. Would that make it not work?
24.75 volts...
Stupid question, did you measure from the junction of R11 & source to the gate and R12 & source to the gate?
If adjusting P1 & P2 has no affect on the gate voltages, I would suspect you have a gate source short.
With the power off and the PSU discharged, check with a multimeter that P1 and P2 are functioning correctly, reset them to maximum resistance.
Power up, check that there is a voltage across P1 and P2, this shows that the JFETs are conducting current.
Apply a signal to the input, check with a scope (or a multimeter set for ac) that you have a signal at the junction of Q1/P1 and Q2/P2.
If you have no signal, the JFETS are probably short cct (24 volts across P1 or P2 would indicate this), power off and order some new (matched) ones, ensure that the PSU is fully discharged before replacing, it is important that you observe the static precautions to prevent damaging them.
If everything is good so far, power off and put in an order for new output devices, they are cheap enough if you are only using a single pair, they do not need matching.
Again, ensure that the PSU is fully discharged before replacing the output devices, and observe the static precautions.
Is this correct?With the power off and the PSU discharged, check with a multimeter that P1 and P2 are functioning correctly, reset them to maximum resistance.
I thought the bias setting pots/variable resistors were set to zero resistance for the set up condition.
Is this correct?
You are correct Andrew, good catch, my mistake, apologies
Is this correct?
The test process I posted earlier is valid if you put a short across the gate and source of Q3 and Q4.
Hi all.
I'm having a problem with one chanel:
adjusting P2 has no affect (p1 does work), I changed the 5K trim pot and still no good.
Any advice- please
Any advice- please
check the board and see if the whiper(middle pin) of the pot have contact with one of the outher pins.
Hey again Audio san
Checked connectors and all seems allright
Anything elso I can check? Can I check if trip pot is okay while its connected to board?
massure resistance between midle pin and the outher pin that is not conected to the center pin. and what is the resistance over the resistor in paralell with the pot? do this resistance change when you turn the pot?
- An illustrated guide to building an F5
