Klampykixx..?
Hey Klampykixx....just out of curiosity for your examples of garage great and sports hall nice kick but not thumpy outside a short distance. How were you set up? All 4 SS15's together stacked? Two on each side? Corner or Wall? etc. I ask because I am finally planning on my horn sub build and DJ a lot of high schools with 2 or 3 basketball gyms for the dance. Just trying to get a reference for output and options since I am yet to hear an SS15 in person.
Jay
Jay
post 1704 shows both setups
in the garage i had them stood up as two towers, which gave a really solid big rumble sweet spot about 2-4m back from the mouths, and stayed fairly constant right back beyond 20m away (in a straight line.) however, i didnt bother testing them in a single stack as i ran out of setup time.
in the hall however, i tried them as towers first, and then as a center stack. and as far as orientation, if you picture two basketball courts next to each other, the grandstand is on one side, and halfway across the second BBcourt at one end was where my kit was setup, aimed diagonally across the first court towards the grandstand
the towers sounded great in the sweet spot, but lacked that big single sub/bass-everywhere vibe
i then piled them together and the difference was massive. i doubt ill ever stack them separately again.
so, much better as a single stack. IMO.
ill up load pics later, pc is being annoying, but the layout is the same as post 1704, second pic.
workable, yes. A couple db down vs the eminence in the 50-70hz range, and more expensive... It is out of xmax at 500 watts, However it does work.
The 4015lf is $100 cheaper from the same retailer....
I have a question,
can you have the same SPL's with 2 ss15's with 4015lf's
than with 4 ss15's with a less expensive driver ( less rms power rating )
just wondering as i have read that is best to drive them not so hard and
stack more instead of build a few and drive them hard
thing is the more compact my setup the better, however in want a stack of 4 in the future but certainly will start with 1 ( car setup to carry ) then 2 maybe i will need a small truck to carry 2 as i got a sentra , dont think that i can fit 2 in the back seat.
Maxo,I have a question,
Doubling Xmax will give 6 dB more output (and requires about 6 dB more input power), the 4015 does not have double the Xmax of any of the suggested cones.
Doubling speakers , each at the same power, gives a 6 dB level increase.
Assuming a high Xmax driver capable of output equaling two lesser drivers, it would require 3 dB (or) more electrical power to do the same “work”, effectively four times the power in one driver, which most likely would result in thermal compression.
All the suggested light cone drivers are designed primarily for BR use, the 6 dB or so more efficiency afforded by the TH design puts a lot more stress on the cone, at X max the cone will have more output than in a BR, but also a lot more distortion.
The distortion is compounded by cabinet losses at high power using only 1/2” material, which flexes significantly even with the 3015LF when driven around 450 watts.
Bottom line: Far more clean output per watt available using multiple cabinets, slightly more output per cargo space using higher powered, higher Xmax drivers.
Art Welter
Something I have heard over the years, but never tested...
Double displacement (cone area): +3dB
Double power: +3dB
Both: +6dB
But I believe there is a flaw there. Wouldn't it be that if you double your cone area AND power, you get +3dB? If you double your drivers and split the power to both (adjusting so they get 50/50 of the same amount of power prior and not letting the drop in resistance at the amplifier push more power than it was), wouldn't that cut the cone travel in roughly 1/2, giving no gain in displacement? Therefor, by doubling your woofers and doubling your power, you gain 3 dB? I have done research trying to find the correct answer and seems pretty debated. Seems simple enough to test scientifically.
I could be wrong on this. I have seen it calculated both ways. Obviously, the frequency response is definitely going to be extended with more drivers.
Double power: +3dB
Both: +6dB
Maxo,
Art Welter
Ic, so even if you use good bracing inside the cabinet with 1/2" material you get significant flexes in the plywood ? i was looking at use 1/2" plywood instead of 3/4" but if 3/4" is the correct way to go... i will take the extra step
,altough does anybody have weighted finished cabinet with no driver of 1/2" material vs. 3/4" material ? to see how much weight you save and if it is worth to add more weight in favor of less distortion or you just plain go with the lightest material to save your back and can live with the negligible added looses
just wondering
Max
just wondering
Max
A sheet of good 1/2" is about 40lbs. A sheet of good 3/4 is about 75lbs. Drivers are 10-25lbs. I choose 1/2" for obvious reasons. The only part of a SS15 as designed that has more flex than I care for is the front panel. A brace there would help. Also the mouth flexes if you don't have a metal grill or other bracing. Extra bracing only gains you a fraction of a db in my experience.
As art is pointing out, when you start getting to the limit of things, you just flat out don't get the extra spl you think you will. All kinds of losses start piling up, and the chance of smoking a driver goes up exponentially too. A pair of ss15 can fit (barely) in the back seat of many small cars, and then put your tops/amps in the trunk. For someone just starting out, that's where I'd go. Depending on your budget/weight you are willing to carry shows which of the 3 eminence drivers you should choose. The budget winner here is the kappa, at the expense of about 2-3db less max output vs the 4015lf. If a pair is all you can carry, and you have the amp, and need the spl -- the 4015lf is the way to go. If you have a truck and can carry 4, well then 4 of the kappa's is pretty interesting for budget reasons. If you have a bad back, don't consider anything but the 3015lf.
Making cardboard mock up's and then trying to load them in your car is the easy way to find out what fits, and what doesn't.
BTW, loading a car is a pain... if you can fit a hitch to your car, and then tow a small foldable trailer like this.... life becomes very easy.... it makes trips to the lumberyard to bring home more sheets of plywood for more cabinets easier too...
[/quote]so they get 50/50 of the same amount of power prior[/quote]If they're getting 50/50 instead of 100/100 the power isn't doubled at all?
Halving excursion equates to a 6 dB output loss, so -3 dB (50 instead of 100)equates to less then halving the excursion.
Note that coupling is only effective if the cones are within each others range relative to the wavelength of the frequency.
That would mean that either one of those two factors isn't effective. If you agree that doubling the power increases SPL by 3 dB, you're saying doubling the cone area isn't effective and vice versa.Wouldn't it be that if you double your cone area AND power, you get +3dB?
@ maxo,
To bring it back to only the Panel thickness is not correct in my view. For instance, I prefer a very well braced ½” panel enclosures above any non-brace ¾” panel enclosure. Working with panels means they will flex no matter their thickness (or they become impractical heavy). Therefore in my view braces are not an option and panel thickness is a personal choice and a matter of your skills.
Braces don’t need to be thick either as long their contact surface with the panel is large enough. To get that large enough contact surface you can enforce the corners of the braces. If you use relative cheap hardwood joints, like they use for windows, it will damp the panel even better.
@ Rademakers,
Tiny correction 😉:
“Note that coupling is only effective if the cones are within each others range relative to the quarter wavelength of the frequency.”
@ Rademakers,
Tiny correction 😉:
very interesting Djim , can you show some pics or examples of how good braces need to be done, i mean to be in the ballpark, i know that many people have their own way to do it and somepeople dont do it at all when using 3/4" material, but the less heavy the better , specially when you are not a teen anymore and your back cant take any more punishment or you cant hire a couple of roadies to setup up your linear arrays 😀@ maxo,
Double power: +3dB
Both: +6dB
you're right. Doubling drivers while keeping power constant does not yield +3dB. IF it did, we could just keep doubling drivers and doubling drivers, ad infinitum, and we could achieve any SPL we ever wanted. Without even touching power. Not gonna happen. Double the drivers AND give the 2nd one the same power as the 1st (which is doubling power) is what gives the +3dB, and only +3dB. Not +6 dB as some claim.
Doubling speakers without increasing power does yield a 3db increase!
Of course this is exponential so for each 3db we need 2 - 4 - 8 - 16 etc drivers.
The other rule is the speakers must be within a quarter wavelength of each other. So as the speaker stack increases in size the maximum frequency that the 3db gain effect applies drops.
At 100 hz the wavelength is 3.44 metres so a quarter wavelength is 86cm🙁
Put simply if you have a pair of bass bins and you place them together, instead of separating them like a stereo pair, you gain an extra 3db, which can be very useful in a small PA setup.😀
Once you get above 2 subs in a row you can run into other problems, including beaming.
You are correct, (and Oscar S is wrong), I did a lot of testing to prove it for David McBean, as he had a few doubts in some of his Hornresp programming:Doubling speakers without increasing power does yield a 3db increase!
http://www.diyaudio.com/forums/subwoofers/204472-multiple-cabinet-combined-response.html
Some of the tests were running multiple cabinets in series, each doubling of cabinets halved the power to each individual cabinet, the output remained the same.
In addition to the 6 dB increase by doubling the quantity of equally powered speakers coupled within 1/4 wave length, the added frontal area effectively creates another boundary, which increases forward gain even more.
http://www.diyaudio.com/forums/subwoofers/184986-horn-extender-wave-guide-th.html
Art Welter
Just to make sure we are on the same page... by "keeping the same power but doubling cone area", we are talking about going from 1 watt to a single driver to 1/2 watt per each driver of two (meaning, same exact amount of power in total)? By doubling your drivers and giving them the same amount of wattage per as before, you are doubling both drivers and total wattage.
People are being pretty unclear about this. If you double speakers, while powering the added speaker at the same power, you will add 3 db. So while the power per speaker stays the same, the system is actually pushing double the power. I think.
Efficiency and sensitivity conversion - loudspeaker percent and dB per watt and meter loudspeaker efficiency versus sensitivity vs - sengpielaudio Sengpiel Berlin
According to that calculator (bottom of the page), I could have 1 driver w/ 200 watts and 99db sensitivity and produce 102dB @ 10 meters. Then, throw in another drivers w/ another 200 watts (so 400 watts total, doubling both total wattage and total driver displacement), you get 105dB @ the same distance. Therefor, doubling your power AND doubling your drivers will result in a +3dB gain, not +6. If you double your power PER DRIVER and double up the drivers, you will have gained 6, but then that's really quadrupling your power. Finally, a single driver with 400 watts will produce the same two drivers at the same power (but 200w each).
So unless that calculator is wrong, it seems that the drivers themselves don't actually "add" to the equation when it comes to gaining decibels, but simply gives you more "headroom" for more power from the amplifiers to become louder.
Hi guys,
Drivers are not completely passive electrical circuits.
You need to realise that "doubling the cone area" also means doubling the motors.
Doubling the motors means doubling the magnet power, which is an energy source!
In other words, a system of two drivers has twice the motor power and therefore becomes two times more efficient (is 3dB) with the same power.
Yes, I agree with with what you said.
- Subwoofers
- Single sheet TH challenge
