Yes. Sorry for forgetting the link.
You're in an enviable position, Lynn. You know what you like and don't like, you know how to build what you want and you have no one to answer to but yourself. You've found yourself at the top of the audio food chain. Many DIYers share some of these traits, few share them all. Count yourself very lucky.I design loudspeakers for my own satisfaction, not anybody else.
LOL! Oh so right you are. The stock version only gives a peek at what is underneath, it's a lot of work to bring out the fullest. But it's there. I was very lucky to have learned that 25 years ago in Paris. Some gals can get a make-over and you might think "It's just lipstick on a pig" while others can go from ordinary to super model. That's the story here.The "hints of greatness" in the Altec A5? Well, the large-format 288 on Altec's best horn, the big multicell, gets a lot of credit, along with the 416 woofer, which has an unusual old-school construction of an underhung voice coil, a light cone with a very effective edge-damping system (which provides freedom from breakup above 2 kHz, unlike most other 15" drivers), and an Alnico magnet. The crossover? Uh, no. The thin-walled plywood box? Uh, no. Those are problems, not assets, but you can't blame Altec for that. Filter design was in a very primitive state when the A5 was designed in the late Forties, and not much was known about box damping.
Altec drivers and horns are works of art, the Altec crossovers were just a piece of work. My main objection to them isn't the parts quality, it's the values of those parts. They are mostly just textbook standard - not optimized to the speaker at all. Except maybe the model 19 crossover, everyone seems pretty happy with it. The very first step in getting these to sound good is a proper crossover. And yes, the cabinets rattled and buzzed and the ports were too big - but that is no hard to correct. Time consuming, but not hard. The design of the Altec 825/828 bass cabinet is pretty good, as long as it's built solidly. FWIW, I've seen more recent JBL cinema cabs that were far worse. How did they get away with it?
I've heard a lot of music and a lot of speakers in my life, the hotrod A5 still remains my favorite speaker. It's the best all-rounder I've ever heard. Sure, some speakers have more detail, higher highs - lower lows, bigger space, more pinpoint imaging, but none sound more like real musicians playing real instruments in a real space. That's what I want.
Your LTO should be very much that type of speaker. I hope it gets built by DIYers around the world and opens up a window into just how much music there is in the recordings we all know.
Does anybody have complete TS data for the GPA416 16ohm Woofer, and frequency/impedance response they can publice?
I have tryed to contact GPA on mail without any luck. What is the price on this driver?
Lynn you describe it has some kind of special edge treatment to reduce peaks in the roll off area, how does that look like, how is it made?
Altec Lansing GPA 416 416-8B Alnico NEW | eBay
You would need to request the 16B.
That's actually from GPA (i.e. "direct" sale). Considering the materials alone vs. the marketplace and "similar" items, it's a bargain.
Current score card, per speaker
GPA 416B-16 c. $350
GPA 288/AH-425 c. $350
Azure horn AH425 c. $275
RAAL Lazy Ribbon as a supertweeter c. $900
This is sans shipping.
Anyone planning 5.1?
GPA 416B-16 c. $350
You know that the 900 RAAL isn't a prerequiste. While not the same level of performance, there are other long ribbons with wide dispersion that can offer a similar integrated dispersion pattern for considerably less expense.
It's also possible that you might prefer it without the super-tweeter.
The Radian 745 Neo is $300. The GPA Alnico 288 is $550. (That's each)
I still think you could do it for about $3000 the pair, with some DIY. Build your own horn and save even more (hint: paper maché)
You could hit $2000 for the pair if you're frugal. They won't be the exact LTO, but close.
Papier mache is a good idea, but of course the problem is the mould. I give full instructions on my website (Azurahorn.com) but in reality it is more work than you would want to go to. An alternative method is to build up concentric discs of 2 ply cardboard (using he Le Cleac'h spreadsheet) and fill the steps.
The profile is not proprietary - anyone who wants to give it a go can enter the input data into the spread sheet and obtain it.
T=0.707
425 Hz cut off
one side wall angle 4 degrees
Throat 1.4"
Mouth diameter 420mm
Having just returned to the fold after a detour round TD2001s on 340 horns and Lowther PM2A on 204 horns I can say with confidence that the design choices that Lynn took wrt the 425 horn are spot on - hard to describe but you get that immediate feeling of it's just right.
martin
T=0.707
425 Hz cut off
Throat 1.4"
martin
T=0.707
425 Hz cut off
Throat 1.4"
martin
I suspect that if anyone balks at about 600 US for custom horns - then this isn't the project for them, regardless (..at least for the time being). The fact is that everything else is *more* expensive, and I'd bet that the crossover done with correct parts will just add to this - substantially. Trying to "save" 600 or so on a 3+k project almost certainly isn't a good idea.
..of course an enthusiast modeler crafting the horns for the joy of it - that's something different.
I built my crossover for about $125 a side and am very happy with it. The inductors are the major cost.
Building the horns is a big project, beyond the scope of many here. But this is supposed to be DIY, right? I was lucky, I got a great deal on my Altec horns so didn't need to build.
Yes, but Pano - you're *magic*.
I've a feeling it's like cooking for the rest of us - you can have the ingredients and cooking instructions down to the very last detail and still f....it-up.
I found a great way to diy inductors is to wind them on 5" or 7" RtoR tape reels. This narrow profile is actually the most efficient (lowest DCR) when you check it on the coil winding calculators. I used paper and oil vintage grey can type caps (keeping pcbs out of land fills). What is the opinion on these?
I guess diy is cheap when you have a shed full of junk, but acquiring the junk pile is big investment
martin
martin
martin
Hehe... those are most definiciously words of great wisdom!
European builders ...
Am I right if I think most of the members here are US-located? For us, poor Europeans these prices are almost double so high. If I am not mistaken the formula to get something into the EU is: (price+delivery cost)*VAT(up to 27%) +customs(~6..8% of the price)
As the only delivery method is air cargo to get 2pieces of GPA 416 might cost 350$ or so.
Additionally, it is hard to make business from here with these guys (GPA, RADIAN, etc) - no WEBshop, no EU distributor, they don't like answering emails ...
On the the hand, there are many nice European products so to find more or less correct replacements for the pieces recommended by Lynn should be possible. The only piece what I would buy from US is the CD - Radian 745 (PB/NEO).
So what are the impact factors to use:
288 -> 745 (maybe ND1460A) (only 8Ohm available?)
416 -> 2 pieces of 12NDA520 (only 8Ohm available?)
RAAL -> RAAL (the only piece which is cheaper in EU)
Any better idea (based on personal experience)?
Yes, well.... the $125 is simply parts cost from Parts Express, so it's a bit of a cheat.Yes, but Pano - you're *magic*.
As Martin says:
Very true, and I had parts on hand so that I could experiment with different values. I don't have tons of spare parts, like some guys I know who literally have buckets full (you know who you are).I guess diy is cheap when you have a shed full of junk, but acquiring the junk pile is big investment
The big cost is R&D. For that I had a DCX2496 active crossover to experiment with slopes, crossover points, filter orders, phase, etc. I did not include that in the cost - but it's important.
I still think that if someone else designs the crossover you'd not be in for more than $300 for the pair, unless you use boutique parts. I did not. Solen, Erse, Janzten, Mars. I don't know what Lynn has in mind for the LTO, but my (or Mr. Hiraga's) crossover for the A5 should not cost USA builders more than $300 at current prices. I think mine is a 12 or 13 element crossover for 3-way.
Of course for the LTO crossover the price is just a guess, as I have not seen the BOM.
I guess any oil filled capacitors need to be identified as containing or not containing PCB's before disposal. In Australia Ducon was a major manufacturer and their products were used in locally made TV and radio transmitters, Beyer/Rola/Plessey tape recorders and many other products.I used paper and oil vintage grey can type caps (keeping pcbs out of land fills). What is the opinion on these?
martin
Coming from the Broadcast industry I learned that any Ducon caps with N or S in the part number contain PCB's.
We used to have standard procedures for dealing with them which involved taking them to a depot and storing them in drums for future disposal. That was originally going to be high temperature incineration, but I believe there is an improved method. The PCB's are sealed in an atmosphere of boiling nitric acid and when removed the resulting compounds are benign in the environment.
Sorry to be off topic, but I will use the dissemination of safety information as the reason.
Keith
Good info, thanks Keith. I found the MSDS below. Looks reassuringly benign. perhaps not the full story.
http://www.nttworldwide.com/docs/PCBsMonsanto-MSDS.pdf
I have read about industrial scale environmental problems in the States rgds residual pcbs threatening water supplies wherever manufacture and storage took place. Obviously the stuff had a great number of uses and was manufactured in huge quantities.
martin
martin
- Beyond the Ariel
