hi exflaco
greetings built this bridged amp but detex design 4 pairs not good for IR2110
WARM REGARDS
andrew
WARM REGARDS
andrew
Andrew these design 100 omhs gate irfp250 no problem to ir2110. better design irvynejay totem pole and 4 pairs ofcourse.
These type design poor bass response, but big power and no buss pumping efect.
Wat the problem you know it? Thanks very much i am very happy in this forum, people participate and cooperate ,very nice place
You made the test wrong🙁..these figures are too bad...probably you saturated the sound card input...Hi CPX
here i am attaching my old class d amp test report
regards
MANOJ
Hi CPX,You made the test wrong..these figures are too bad...probably you saturated the sound card input...
i agreed my sound card not good.when i increase level it shows clip distorted,i can't set to the correct set,and my motherboard inbuilt sound card damaged just now.tomorrow i will purchase a good one
regards
Manoj
Hi all
my digital crossover with limiter (LF & HF)finished.This is for Active Speaker (Bi AMP)
Manoj
Manoj
Manoj:
What kind of resitive divider you have used?
CPX
i used series 4k7 ground 6k8 with 1nF (2) series 4k7 ground 4k7 with 1nF (3) series 10k ground 6k8 with 1nF (4) series 1k ground 6k8 with 1nF
today i directly connected to input with very low volume, unfortunately my sound card damaged.
MANOJ
For initial tests a 1/10 divider with 100 nanofarads to ground is enough.
NEVER connect directly, of course you sound card got damaged.😀
Also never make connectios while both amplifier and computer are on.
???? D-class 1200w.mp4 - YouTube
that is amp in the few posts upper i started him its cool but need delay for good start
Hi CPX
Today i got Yorkville schematic comparing with my circuit its all most same what i did
so i quit THD measure( save my new sound card ) if you need schema i will send you
Manoj
Manoj
Hi All
Yorkville ls800 (1500W 18" Sub woofer) using lm311/555/ir2110/ir2110/IRFP31N50 +130V -130V bridge config.
regards
MANOJ
regards
MANOJ
Yorkville free
http://www.yorkville.com/downloads/servman/smls801p.pdfYorkville all model free4all in the web page 145v igbt out non ucd limiter (13600)ocp
Manoj:
This in not a solution, THD depends on implementation not on schematics used.🙁.With correct divider and ground connections there is no danger for the sound card.
Hi exflaco
that carrier based class d using fsw=@80KHz Max. IGBT freq. is 150KHz
Manoj
Manoj
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
