TH-18 Flat to 35hz! (Xoc1's design)
Hi Oliver,
The DSL’s all seem to use relative high compression ratios and capable drivers. I think the trade-off for less capable drivers is less compression at cost of low end or high compression at cost of compression losses (lower excursion than predicted).
(highest pressure zone just outside the throat to prevent turbulences at the throat)
I think Art was right, the "V" throat seems to be intended to increase the horn-path and correction of the pressure zone. Later DLS designs don’t have anything that looks like cone correction at all. They can afford since they use capable drivers and several developing stages; model-build-measure-remodel-improve-rebuild-measure...
I like Epa’s view of post#835 about cone correction at S4. Perhaps something like; the percentage of the horn-path taken by the driver, divided by the factor compression-expansion difference between S2 and S4.
(Martin, hope you have a speedy and comfortable recovery!)
Hi Djim and epa,
Thanks for your explanations. That's about what I was thinking, I still don't quite get why one cannot get there from here with a throat chamber/S2 opening. Oh well. The throat your picture shows looks like it might be great for a symmetrical TH. Djim your throat picture has it all: MDF - BB - OSB..... :).
Regar
Sorry Oliver,
Was in a hurry...:eek:
Hi Djim,
Thanks again. It 's like I thought, the cone becomes part of the sidewall of the horn path, but there is also a very small compression chamber. I'll attach what I was thinking of (something like Klipsch's "rubber throat"). The whole thing becomes completely untractable without Hornresp/AkAbak.
  • De_Throat_1.pdf
Hi Oliver,
Both volume and throat area determine the compression ratio. Just be careful you are not trading one for the other : - ) But I get what you mean now, thanks for clearing up. My reason to choose for a small as possible chamber and a large opening is to keep the speed at the throat-edge as low as possible and trying to keep as much upper band but I agree that larger chambers can have their advantages when it comes to low frequency (and shorter horn-path means less folding).
You were right, my drawing was meant for Sym-TH's. For more traditional folds and easy build I was thinking.....
Figure 1. needs a 'broom' or 'stump' on the end to prevent turbulences.
Hi Djim,
Maybe we could look at your figures in Post 845 as having S1=S2 in the middle of the cone with an small "stub" or damping chamber attached to the right towards what used to be S1 with this "damping volume" performing a similar function as the 1/4 wave and Helmholtz resonators we pondered about in the Collaborative thread?
That brings up the thought, what happens with two drivers?
  • De_Throat_2.pdf
Hi Oliver,
Interesting, any specific post of the Collaborative thread I need to look at?
I simulate it pretty conventional, actually. To make it work the S2 area need to be smaller as S3 area and S1 area, otherwise the pressure zone shifts.
About the 'two drivers', that's what I used in my dual-tham or PPTH Tham, as you might remember :). To be honest I really don't get why dual 15" driver TH's aren't more popular for PA. It beats the crap out of any 18" design when it comes to input/output in relation to system volume. The dual tham we designed were about 440 litres, played 40Hz with authority, low cut at 30hz and beats the Cyclops on all levels.
Nevertheless, you can discuss the advantage of PP-settings with quality drivers for PA. If you point the driver magnets to each other in the same S4/S5 area you can gain a couple of dB's at the 1/4WL between them. If you do it right you can make that happen around full wave or 5/4 of the horn, there were compression happens.
Hi Djim,
Looking back at the Collaborative thread my thinking was mainly directed at the upper frequency peaks and at response extension; don't know how applicable that really is to these PA THs. I asked a question in Post #1004 and followed up in 1012/1013.
I found some additional references in Post #1499:
"...Post #1139/1146/1175: MaVo shows pictures of the interior of the DTS20; Post #1140 explanation by cowanaudio.
In Post #1147: Marcello provided a link to the tapped horn patents.
In Post #1174/1183: jnb shows the effect of a resonator in an AkAbak simulation, with and without damping (e.g.: polyfill stuffing in a PVC tube).
In Post #1187: Cordraconis presented his AkAbak for Dummies script with explanations for the individual elements...."
Do you have a link to your "dual-tham"? edit: Just found it in the Single Sheet thread Post #1247.
Hi Oliver,
Although I am not an Akabak user it was an interesting read, only a pity they didn't put up pics with their findings for 'comic' readers like me ;
What I do know is that simulations can become tricky above the 1¼ WL resonance of a 1/4WL folded bass-system. Tiny differences between the ideal world of prediction and the world of clumsy wooden dimensions can begin to mesh up things. Also the use of a point source rather than a true area source and the absence of real world losses can be a handicap. In other words creating small band absorbers above 1¼ WL is difficult for 'one shot one trail' predictions.
As you already considered, how important are spikes and dips above the sub range? Although high level PA subs are usually not used above 120Hz, there is still a crossover-area that needs to be considered so your remarks are legitimate for me.
The dual-Tham project dates from 2010 and I showed you in May 2011 in post#63 of the PPSL thread :)
Powersoft has a good reputation :) (tis geen hypex).
You don't need to rush any longer cause I'm on my way now.
I have complained about the absence of the 4 Ohm data sheets.
It probably wont help much since they prefer to race in their red cars than spending time online :D
(tot laters)
Hi Djim,
Thanks for the links, the dual THAM deserved to be tried. I had forgotten the mention in the PPSL thread. When sketching dual driver boxes I've always ended up with cone to cone or magnet to maget configurations, or the THSPUD driver arrangement (it makes for a real efficient use of wood). Here is a dual sketch of mine (now that looks "different" looking back): http://www.diyaudio.com/forums/subwoofers/131852-live-sound-specific-tapped-horn-thread-35.html Post #350.
Djim, the throat details you are showing cannot really be simulated in Hornresp, that forces you into making educated guesses at which change in Hornresp will produce the desired or measured results. That's the hard way of doing it. I'm not a regular AkAbak user either but sometimes it is just necessary to go that route. Tom Danley is quite emphatic about using both AkAbak and measurements, e.g.: http://www.diyaudio.com/forums/subw...tive-tapped-horn-project-262.html#post1703164 Post #2618. Also, you could break that throat area up into any number of sections, and even get an estimate on the effect of damping material. You could even break the driver up into multiple drivers, and set those at the cone angle, etc.. Lot's of work, but, may be worthwhile.
