UCD 25 watts to 1200 watts using 2 mosfets
>>>which are the best pairs for output fet buffers among the below
2n5551/5401 , 2s/c2655/a1020 ,2s/a1013/c2229 , bc327/337 , bc368/369 , bc546/556 , bd139/140, mje 340/350
The ones with highest gain and current, but personally i would use dedicated drivers like tc4420
tc is difficult for me to find pls among the above which can work mean while. thanks in advance.
thanks a lot exflaco i will use your schema but will parallel outputs like irf540n 4 pairs / irfp260n 5 pairs . i will post schema , pcb and pictures once i am through.
hi
greetings which OCP is better triell ocp or detex irs2000 please can any one guide me
want to make pcb 3 pair fda90n20 with bjt totem please any feedback is welcome
supply is 80 volts dc+/- load 2 ohms
warm regards
andrew lebon
bridge
Stewin could move 2 pairs irfp250 gate resistor 100ohm directly from ir2110 +- 75- 90v
Andrew OCP Detex same the Crest class D amps ,Lm311 and 555 ,triell ,more simple a npn transistor and 555 two work fine ,a lot similar protecction on class d amps you only parallel 3 X1 ohms 5w resistor paraleel , and adjust the trimp to the desired humbrall protecttion,(sorry my poor english) more efficient + and - v sense ,another way old AB amps like Peavey the shunt sense resistor to gnd series to the speaker,y share schemm soon..
ocp
Hi Exflaco
greetings thank you for replying and more important the COOPERATION i appreciate your efforts thanks
warm regards
andrew
bridge designs
Could you share, i test it, look very good wat its awfull poor its nice design .You similate it?
Another good design bridge
Back
Top
