Nelson Pass: The Slot Loaded Open Baffle Project
Since there will be some air loading effect, Fs might be lowered somewhat, but I would not expect a gross effect.
Nelson claims an SPL increase, but I have not seen any evidence. It is still a clever design for an OB subwoofer, though, since in this setup, the acoustic path between front and back side of the driver is optimized given a certain baffle size.
vac
Tight slot lowering Fs in NPs slot loaded baffle?
Maybe this was already covered but ... does having the drivers facing each other in Nelson's push push configuration lower the Fs of the drivers? If so any estimates on how much? 10Hz? Does it affect the Spl? How much? 3dB?
Having followed this thread from the start, I have ended up reading all that I could find on PPSL and Ripole as they also utilizes slots.
The Ripole discussion contains a lot of info on how a tight enough slot (1/3 to 1/4 of SD) will lower Fs because of air-loading. This is a part of the Ripoles design objectives. I can not see why this effect would not affect NPs slotloaded open baffles as well?
Another effect is the quarterwave resonance in the slot/plenum. As far as I can see, this has not been addressed much in the slotloaded open baffle discussion. An interesting comment on this mecanism comes from Rudolf who has a lot of hands on experience with slots i Ripoles: http://www.diyaudio.com/forums/subwoofers/86466-drivers-parameters-ripole-subs-2.html#post1009075
Rudolfs comments was also a wake up call for my aspirations on trying to make a PPSL with 12" or 15" and to try to extend the response >400Hz to meet my JBL 2360/2446 combo. Having read only PPSL threads I was under the impression that it could be possible to extend the response beyond 400Hz if I made the slot as narrow as possible and if I did fill the back corners of the slot. + a few other minor tweaks. Now I have realised that it is the deepness of the plenum that sets the frequency of the resonance and that a PPSL with a 12" or 15" is best used as a <100-120Hz for high quality home playback purposes.
Joined 2000
Some measurements
A friend ran some measurements in order to help with beaming issues and room interaction. There are 5 graphes that may or may not be helpful to others. After some placement adjustment, we were able get a good respsonse that was well balance. In the end, the beaming was fixed and the imagine was improved.
Tests were done around normal listening levels. We did not run max SPL tests, and I didn't think to ask at the time. Like I said, we were just trying to adjust for overall balance. My friend left sound absorption panels to test around the room. He'll be back at some point. Might ask for max SPL readings then.
Vince
ps, inserted a photo of speaker for reference. It's built as described in the original article.
  • Listening Position - Final Speaker Location.pdf
  • Listening Position - Intermediate Speaker Location.pdf
  • SoundPro Report- Left Front-Mid Field (4') - Averaged Drivers.pdf
  • SoundPro Report- Left Front-Near Field-Bass Drivers.pdf
  • SoundPro Report- Left Front-Near Field-Main Driver.pdf
I posted this link to some scale model results I measured back when the thread started. It addresses SPL gains which do not materialize.
As for the lowering of Fs, that is highly dependent on the effective air mass load in relationship to the driver moving mass. There would not be much of a change in Fs (or Qts) for a heavy cone driver. For a lighter cone there could be a decrease in Fs and an increase in Qts yielding slightly higher SPL around Fs. But the higher frequencies would basically remain unchanged except for the 1/4 wave resonance. I would recommend rolling the response off well before the 1/4 wave resonance for obvious reasons.
