Hi Prasanna
greetings there are no schematics just make pcb put components and enjoy
the sound ONLY if you have the proper core make it otherwise
warm regards
andrew lebon
warm regards
andrew lebon
Hi Jcoelhogsia
greetings no i dont have bridges pcb already d class is so powerful and
bridges only good for 8 ohms load
warm regards
andrew lebon
warm regards
andrew lebon
Do you use sensing tranformer or resistor?
Do you use di/dt limiting inductor or not?
Have you tested this protection with short on output and then feeding high frequency sinusoidal signal?
About Core
Sir, I have these core from old Computer SMPS. the size of core u can see, i wanted to know that can i use it with IRS1500D or for irs900D?
Hi Prasanna
warm regards
andrew lebon
they will certainly be hot as a soldering gun, but if you have no option, use a hack saw to cut 1mm gap which will atleast help.
the best thing is to use the EE or the EI core from that PC
>>>> coil 24turns,use a piece of old CD to make 1mm gap
refer to previous posts, there're even instructions by other DIYers on how to go about it
you can incorporate the OCP protection with any UCD or non UCD class D amps
The schema and the artwork are in the links below:
diysmps
diysmps
Thanks for the schematics, i was just curios, i have my own protection that senses output current. Try making the test i wrote about..
hello sir.. good news ??HI Aman
greetings i heard some good news about you
http://torrentz.eu/3625c1e8dbb19c4e4668bbc706e8a168678af483
andrew lebon
Veer ji andrew sir ne bataya hoga aapko core ke bare me. mere liye bhi kharid ke rakhnahello sir.. good news ??
lollllllhey guys post the schema of the MARAAGE and keep the DIY spirit up
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
