Gamut amplifier
Whoa !!!
Think I'll hold off on a build of this for a while.
I'm a bit surprised that the bi polar push-pull feeding the "Bricks" (power MOSFET's) doesn't cause its own set of issues.
You probably know this, but the original IRF's in SOT-227 cases, like the IRF FB180SA10, used parallel MOSFET's.
Where as the newer IXFN 180N10 are a single die.
...... schematic 😉
Alex.
Thank you. In this case an other thread is here:
http://www.diyaudio.com/forums/soli...h-pull-pull-like-gamnut-whats-right-name.html
Are you A. K. on AAA?
Reinhard
Yes.
He is out of business,
Reinhard
Thank you. here is the URL from webarchive:
GREENWALL HiFi Audio single ended Verstrker Amplifier Horn Lautsprecher Loudspeaker CD-Player
Hallo,
had a close look at the greenwall amps. They are Zen Amps. Look at www.greenwall.de
Reinhard
Are there schematics of that amplifier models ?
They aren't the first. A certain outfit in
North Carolina also plagiarized the Zen.
Which currently commercial available models of plagiarized Zen topologies exist in the meantime?
here a German DIY project:
http://www.methe-family.de/die_endstufe_sess.htm
