Would Amtrans be a possible substitute for the Rikens?TIA
Just yesterday I installed a couple Amtrans resistors in the output path of my active xovers. They impart a smooth, spacious quality that I didn't have with PRP's in place; very pleasant. I suspect these are the same qualities people like about the Rikens, and should be used sparingly. I expect that they would exhibit those same qualities in the FE amp. They are one-half inch long, though.
Peace,
Tom E
Dario i've just noticed that you installed LM317 on both positive and negative rails of opamp. There is any special purpose ?
Yes, LM317 used as a CCS has better rejection than LM337 as CCS.
See http://waltjung.org/PDFs/Sources_101_P2.pdf
Way off topic
Some of you may have noticed that I changed my avatar.
This weekend, I found the device in my avatar in my father's desk drawer. It is an original George Philbrick Op Amp using tubes from 1952. My understanding is that it is the first op amp ever produced commercially. I felt like that deserved a minor place of honor, even above Frank.
By the way, it is sitting on a coil of solder and the op amp is about 55 mm in diameter and about 120 mm tall, including tubes.
Jac
Jac
Jac
Not too far off topic; its historical. Post a proper picture of it
For the two Elna RJH 220uf i have in my drawer only 35v version. Would be a good idea to order some 470uf/50v ones as the 220uf/50v is not existing on ebay ?
I'm running on 2x24x toroids wich is around 33v measured during operation.
35V is a too low rating for long therm use, it may work while you wait for 50V rated caps.
Boards arrived. Thanks Dario
Fine Paul, thanks for reporting
The boards arrived also here and in the weekend i will start some soldering. They look stunning and they are a bit bigger that seem to be in the pictures.
Any opinion about Kendeil lytics or any other suggestion apart Mundorfs ? I was thinking to buy 4 of them 15000uf/40v
Please....... Post a proper picture of it
This looks like a cool project. I have a pair of Avel 250VA 25V+25V torroids like this one:
Avel Y236652 250VA 25V+25V Toroidal Transformer 122-625
Can I use them for these boards? With 25Vac secondaries I'll get around (25 * 1.4) - 1 = 34Vdc. Right?
No.
assuming the mains voltage is Vac and the regulation is R percent:
The DC voltage will be ~
Vdc = Vac / Vspec * Vsec * [R/100}+1 - Diode Vdrop.
For a 115/230:25+25Vac 7% regulation transformer running on 127Vac (maximum mains tolerance) and delivering zero output current (except for smoothing capacitor leakage current) expect ~ +-42.3Vdc
When the chipamp/s is/are drawing quiescent current expect the PSU voltage to drop ~1V to ~+-41Vdc.
This within the maximum specification of 84V given by National for their 3886 chipamp.
Your mains voltage will vary by ~+-6% either side of nominal.
No.
Ok thanks Andrew. I forget where I got my estimate. Maybe one of Sloan's books? 42Vdc sounds too high for this project, or am I wrong?
+-42Vdc (84V) is the National specified maximum for a 3886.
Your normal mains voltage is <<127Vac.
Measure your supply voltage without killing yourself. Then you can predict what to expect from your PSU before you buy it.
BIG OOPS.
I omitted the sqrt(2) term from the above calculation.
Vdc ~= Vac / Vspec * Vsec * [R/100}+1 * sqrt(2) - Diode Vdrop.
BIG OOPS.
After searching the older Mauro Penasa MyRef thread, I found that this guy in post 1500 used the same transformer:
http://www.diyaudio.com/forums/chip-amps/54571-my-audiophile-lm3886-approach-150.html#post764510
in addition to three others. So I should be good to go but will measure them when I get the chance. He also claimed no difference in sound between the Avel 250VA, 330VA and 625VA models.
- Chip Amps
- My_Ref Fremen Edition - Beta build/Fine tuning
