UCD 25 watts to 1200 watts using 2 mosfets
IRS-900
T68kv, sis favor can you post the diameter size of the toroid inductor and the wire gauge plus the no.of turns...? 😀
I'll see if I can find similar size's on 2nd hand boards being sold in Raon area, I've been seeing a lot of boards with toroids in it, I can't DIY at the moment I just burned my pcb drill 🙁 I might as well go parts hunting for the meantime.😀
Thanks!
Hello
Hi Exflaco
greetings please check pcb with schematic for mistakes
sameerx1
I'm used IRFP460 , schottky Diode is better , and R gate i using 22 ohm 🙂
Sorry All , diode boostrap is FR207 or Diode has Vrrm >= Vcc .
And this is my last check .
hi thienchay. have you built the irs900 pcb? seems that the pcb is different from the schematic at the cd4049 chip.
the pinout for the cd4049 chip is messed up at your pcb and at the original pcb from detex. anyone have successfully built the irs900d?
