Could you tell us more about your brothers system ? Especially, what speakers ?Exactly, you can see them on my brother's build:
Also, about trafos, this one seems to fit the need but is expensive ($260 usd for a pair including shipping) and probably not Shilcar.
Very Nice Setting. I was just being silly 😉
I've been down that road where the attempt to do a black piano finish cost more than the wood, drivers and crossovers. Great fun but hardly worth the time and dollars evolved.
Parts Express DIY Project
back to FEs.....
squalor, that's the one we were looking at some months ago. OOUCH!
back to FEs.....
Yes atupi, nice playground. Having a teddy bear like yours to guard my system would be a comforting thing.
CD Player Marantz CD-6002
Speakers Infinity Classia C-336
AV Amplifier Yamaha 667
MyRef FE power amp
Neotech UP-OCC Signal cables
Neotech UP-OCC power cables
That R-Core is chinese, it seems good quality but the 4 secondaries (2x24V + 2x12V) are not a good thing since the power will be splittet amoung them so on 24V secondaries you will not have 200VA, IMHO.
dario, do those french r cores have any kind of varnish smell? this is the only reason why i'm staying away from r cores as i find the smell present on pretty much all chinese trafos, which annoys my nose too much 😛
i see that the rcores i questioned about are in fact shilcar. in that case i already got my answer from you a while ago. 😉
my new questions are, does the smell dossapear in time, if so how long?
and would they make it with different material for eu directives when branding it as selectron, hopefully using non-smelly varnish? 😀
I confirm that when new they smell a lot and also that after some weeks of use that smell disappear.
do they heat up during normal operations? i wouldn't mind airing them out by a window if it can be evaporated without heat.
5 partecipants so far received their boards and all extra boards have been shipped.
Please report when boards arrive (pictures are welcome too 😉 )
Just a bit.
I really don't know if airing them would do the trick but I guess it will help.
Just a bit.
I've started the build thread:
http://www.diyaudio.com/forums/chip...emen-edition-rc-build-thread.html#post3107316
Please use this thread and not the build one to report when boards arrive.
Unless you have something specific to ask avoid posting in the build thread until I finish the tutorial posts (it will take some hours...).
That's super Dario !
Off Topic Again 🙄
atupi, If you haven't already tried it, will you cover the TV with something like a large bath towel when playing 2 ch stereo and report if you hear a difference in the stage. I use a big chunk of carpet.
Off Topic Again 🙄
Bob, i already did that test covering tv but no obvious difference in sound. Maybe next speakers will be more resolute and will make a difference.
L.E...oh...forgot to add i expect more pleasing results also from FE version.
Threads
Dario,
Just for clarity.
Let us suppose that I complete the FE RC build and they work fine. At that point, I'm playing around a bit and trying a cap here and a cap there. From your preference, which would be the better thread for reporting results?
Jac
Dario,
Just for clarity.
Jac
On the topic of component swapping I have lost track of how many places we have the option of experimenting with. I know I did not order enough sockets from mouser and I want to add them to my next order. How many is a good number, with a few left over for replacements?
I am getting anxious to get started even though I am behind on my preamp build😀
I answer again since the previous was sent with my mobile so it was a bit too synthetic...
Everyone is free to use the new thread for anything that regards RC boards, like your example.
Simply in this initial phase I would like to keep the tutorial I'm doing coherent, after I finish it, post freely.
On the contrary reports that boards arrived belongs to this thread.
I hope it's more clear now... 😉
There are no limits... obviously TH positions are easier to experiment with. 😉
The best thing for all us is to compare new parts with BOM ones so to have a common base.
Not less than 20 if you want to experiment with a lot of positions.
I can't wait too for builders comments... 🙂
Hi Dario,
Do you still have a pair of the boards?
I just come across this thread.
Rey
Rey
- Chip Amps
- My_Ref Fremen Edition - Beta build/Fine tuning
