My_Ref Fremen Edition - Beta build/Fine tuning
Do you have any left? I would like a pair.
I also would like to get 2 PCBs if available. Thanks.
Yes, I still have boards.
20€ for 2 PCBs (a stereo set)
9.5€ shipping for Europe
12€ shipping for rest of the world apart oceania
13€ shipping for oceania
5% Paypal fees on grand total.
PM me your PayPal email and shipping addres, I'll send you a PayPal invoice. 😉
C12, C32 and C30 (C7 too)
After some weeks of enjoying the green FE RC boards (populated with FKP2s) today I've swapped the 3(4) caps in title with Amtrans and KP1834s.
I already knew it would have been sounded better but swapping all of them together made a not small difference: bigger soundstage, more refinement, added musicality.
I can't wait builders feedback! 😀
attachment.php
This may be helpful. - Removal of Solder Using Solder Wick - YouTube
If the lead has been removed from the pad, slowly draw the wick across the excess solder, being careful to keep the wick hot as you lift it to avoid tearing off the pad. Extra liquid flux applied to the wick helps a lot. You don't need a lot of pressure once the solder starts to melt. If you have enough room and can do it safely - do the same on both sides.
I have also used some scrap lead wire by heating it (the wire) with your tip and have the excess solder attach to it while inserting through the hole. Buy some super cheap resistors from Radio Shack if you don't have any cap or resistor lead wire lying around. I keep most of my trimmings for just this purpose.
Good to hear from you again.
