Photo Gallery
EF86, EL84, EZ81 phono preamplifier with output transformers.
808 s.e. amplifier
this is my last amplifier with 808 in S.E.
Double regulated power supply for input stage and driver, H.V. power supply with gas rectifiers for final stage.
Cabinet cut from solid violin wood.
Disabled Account
Joined 2010
You know,
I think thats a great lookig amp.
The more I look at these images the more it reminds me of Unison research..The 845 comes to mind..:)
How did you cut/shape the wood?
Do you have any shots of inside?
M. Gregg
This is becoming a series; the 3rd high power 500W Williamson amp on a revamped older chassis using the identical circuit as those previous using a duality power supply B+ at 325V and 650V, this provides a conservative class A 50W and AB1
275W /ch resp. The wiring is about to commence. PCb's completed and tested; lower RHS, bias fail watchdog, logic switching, line softstart; lifted 6.3VDC board; (neg board hidden) The top right is the 1kW pfc module. Many caps have nomex tape to avoid damage to the very thin outer insulation tape that many have nowdays. All grid stoppers are Allen Bradley carbon types.
Tube lineup; 8x EH KT90; 4x 12BY7A diff slam drivers as triodes; 2x ECF80 p/s front end as triode. Output transformers (2x 15kg) Majestic (UK) custom spec wound. 15Hz-75Khz # -3dB. The distortion from the other amps was very low; typ 0.1% at full power 550W in bridge mode.
Later, more on the approach regarding testing. The loop stability and response of the series of amps were designed on the graphical approach; typical of the 1950-60's. Computer emulation used was for optimising the switchmode power supply and number crunching Excel graphics. A USB bus is provided for studio MI interface, to provide a programmable B+ droop for guitar work and standby mode at 150V B+.
This power amp is for those with a proven record in power & system electronics; the 650V B+ with all the Joules, can do considerable damage.
650V is an awkward voltage; many DMM's have a 600V limit; and particular care using the correct probes with digital scopes; and ones own safety approach is paramount.
richy
