Aucosticraft the 3200 is for sub low d'ont work fine at complete range ,a good PA class D lows , class H mids , And class ab higs
Sameer you pcb a litle mistaque the-v rail is floating must be conect the zener positive to grnd ,coul share speaker delay and dc protect schematics'? tanks
Has anyone seen the performance of this amp with 20Khz input signals ?
its giving me problem when I Use 20Khz as input or mix 20Khz with 1Khz signal. the circuit stops oscillating.
You have bad layout..post it so i can give you some advice.🙂
"Un site d'audiophile" enceinte en béton - amplificateur mosfet ...
hi Exflaco
greetings this is the site for dc protect schematic posted by sameerx1 use BC547 BC557 for bc560 550
warm regards
andrew lebon
hi Exflaco
warm regards
andrew lebon
Stewin the protection work fine short circuit, and low imp ,tested
thanks exflaco. pls post schema
Thanks CPX, but the problem was when I simulated.but When today I re simulated it, it worked perfectly fine. ( I do not have oscilloscope.)also the physical amp sounds good.I am loving it.
About selection of Strands.
I was wondering about , what should be considered while deciding the number of strands for coil (for the skin effect). should we consider PWM frequency or the audio frequency range?
WOW::: the planet bigger......a 600 600 ohm aislattion
amplificador classe D 4700wrms 1ohms o mais potente do mundo C/ 142x142mm e peso 450g - YouTube
Hello all Diyer 🙂
This my new class D , and i 'll checking it soon 🙂 .
Thienchay, nice spacing you got there, it looks like you are using different parts is it a modified version? any plans on sharing the bottom artwork for toner transfer?😛
Hi all!,
I wonder if anyone of you had a clearer resolution of the pdf file for DIY share, using Detex IRS900, I have the Detex artwork but I don't think it is going to be successful on laser toner transfer, the image is so poor 🙁
Hi all!,
hi Thienchay , please remember the schematic also
hello
geetings what should be the ideal permeability of core for dclass core since i am not so sure is 125 permeabilty the best core material in SENDUST KOOL MU material
warm regards
andrew lebon
warm regards
andrew lebon
hi andrew check yorkville service manuals for class d powered speaker, they are using cool mu cores. magnetics 77191-a7 if i remember it right
hi Gerry
greetings thanks for the information how are your d class amps playing
warm regards
andrew lebon
warm regards
andrew lebon
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
