500W PA amplifier with Limiter
Hello APEX,
i finished your amp and i am really pleased with the sound.I get 45mv dc at the output.
My problem is that when i connect the output of the amplifier to the protect i get -78mv dc at the output and the protect circuit turns the speakers off.
All connections are ok i have checked many times.
Any help would be greatly appreciated.
Dear Regards
Protect GND and amp PSU GND must be connected.
My B500 in progress....
Apex B500 please is some one see any errors let me know
Hi guys!
I was doing this layout and I'm not sure if I got it correctly I spend maybe more than 5 hours or more, please is some one can see any error please let me know I have also the Sprint Layout format so you can use it too, I will share this for you guys. my brain is like this :hypno2: :scratch1:
vargasmongo3435
I'm doing Apex AX-14
I was doing that for a while but my brains are about to explode :hypno2: to much thinking trying to keep it as the original my friend, right know I'm working on Apex model AX-14 here is a small pic not done yet. 😛
vargasmongo3435
Dear Apex,
Good day and hope all is well with you and to all DIYERS.
I finally finish my B500 and my rail voltage is +/- 76VDC, but on the testing process i connected Input Ground and PSU Gnd as per your instruction but i'm still getting DC OUT (57VDC).
Please kindly check if i have mistake i attached herewith the pictures for component layout and copper side.
Looking forward your kind expertise/help and thank you in advance if anyone can help.
Wiljj78
