Hello APEX,
i finished your amp and i am really pleased with the sound.I get 45mv dc at the output.
My problem is that when i connect the output of the amplifier to the protect i get -78mv dc at the output and the protect circuit turns the speakers off.
All connections are ok i have checked many times.
Any help would be greatly appreciated.
Dear Regards
Protect GND and amp PSU GND must be connected.
I did this and now i get -20DC at the output.
PSU GND,OUTPUT GND and CHASSIS should all be connected right?
-20DC V or mV?
I like those monster toroid power supply, where can i find it here in Philippines? some body need your advice.
Ronald
^rs-philippines or element14......
Thanks sir Tony,
i need 50 0 50 vac @ 20amperes how much would it cost Php?
regards,
Ronald
Thanks sir Tony,
regards,
Ronald
Check this out...
Buy Toroidal Transformers Transformer,toroidal,1000VA,0-230V pri,50/60Hz,2x0-50V sec Nuvotem 1000P1-2-050 online from RS for next day delivery.
or
Buy Toroidal transformer online from RS Components
Mr. Mile,
Can i use PSU-7 for B500 or SR200???
Please advise...
Wiljj78
Yes, but without overload protect
hi apex sir ,
can i supply 100vdc for this 8pair tef? what are the changes i have to make?
if yes, then what is the value of 5w ic resistors?
You mean the protect of PSU-7 not suitable for S200 & B500???
If not what are the recommended PSU with soft start & protection for those amps??
Thanks & Regards,
Wiljj78
Apex B500 please is some one see any errors let me know
Hi guys!
I was doing this layout and I'm not sure if I got it correctly I spend maybe more than 5 hours or more, please is some one can see any error please let me know I have also the Sprint Layout format so you can use it too, I will share this for you guys. my brain is like this
vargasmongo3435
Hi guys!
vargasmongo3435
Dear Apex,
Good day and hope all is well with you and to all DIYERS.
I finally finish my B500 and my rail voltage is +/- 76VDC, but on the testing process i connected Input Ground and PSU Gnd as per your instruction but i'm still getting DC OUT (57VDC).
Please kindly check if i have mistake i attached herewith the pictures for component layout and copper side.
Looking forward your kind expertise/help and thank you in advance if anyone can help.
Wiljj78
Wiljj78
- 500W PA amplifier with Limiter
