UCD 25 watts to 1200 watts using 2 mosfets
detex design
my irs900 by detex audio
look chestap vedio it has smps at the back its not direct hahahah
Author
teste do amplificador de 3200w que tambem pode ser ligado direto na rede 127v sem usar o transformador mas é recomendavel usar sempre o transformador de 70+70 volts de 25 amperes ELE CONSEGUE TOCAR ATE O MAXIMO DE 3600W RMS
test 3200w amplifier that can also be connected directly on the network without using the 127v transformer but it is recommended to always use the supplied 70 volt 25 amp +70 HE CAN PLAY UP TO MAXIMUM OF 3600W RMS
