Bass for my soldier
Forget to post this picture
polyfill stuffing in the box
Hi Nathenry,
Post #321: "...stuffing..."
That's a start, as discussed before, this is something to play around with.
By the way, the upper horn/driver do not have to be mounted inside the Beta-12A-2 horn, they can be in their own enclosure,which would give you more freedom of placement, and maybe make the building of the mid-horn easier.
Hi Nathenry
This is a good idea Oliver. Thanks
But what would need to be change and the beta-12a horn drawing if the upperhorn/driver is in their own enclosure.
Hi Nathenry,
"...what would need to be change and the beta-12a horn drawing if the upperhorn/driver is in their own enclosure."
Nothing really, you would keep the mid-horn just as epa designed it, and you would not have to worry about providing cut-outs for the upper horn. Might make it a little easier, and speed things up.
that looks great.good work :up:
i cant see if the front of the horn is flush to the outside or not.
i had an ofset so you could mount a grill
doesnt make a difference in practice.
here is the pdf
the "phase plug" has the same maesurements as the centerpole piece.
making progress.😀
if you would make it 13*13 inch,and the same depth,it wil be between 10 and 15 ltr wich is perfect.
some lining against the walls of the rear chamber.
1 thing ,make sure to double check the distance between the "phaseplug"and the speaker.
i see the cross is about 3/8 back from the front,this means it sticks out 3/8 cm more then it should on the back..
this is not a problem as long as you double check that the cone has the clearance needed.
1/4" is ok.
Hi Nathenry,
eap, Post #335: "...double check that the cone has the clearance needed."
You can alway twiddle away at the extensions of the cross on the plug. A minimum of 1/4" is important, that's only ~6mm.
In the rear chamber you can always take up volume by lining the chamber with styrofoam, e.g.: from old packing material, or Home Depot. You could start with a few layers of closed cell foam (styrofoam), and then add a layer of open cell foam and fiberfill.
making progress.😀
1/4" is ok.
Hi Nathenry,
I will pass on the information.
Thanks Epa and Oliver
Hi Nathenry,
EPa or Oliver, can we use styrofoam to make the phaseplug.
Hi Nathenry,
Post #338: "...can we use styrofoam to make the phaseplug."
I have not seen styrofoam used to take up extra room in the front (throat chamber) of a driver. I would suggest to stay with wood, as per epa's initial suggestion.
Maybe PM epa as to the DCX2496 setup.
I'm amazed how much you have gotten done in a very short time.
