StevenZ's Alpair 12P Build
Yea, I know. I've built a couple of crosscut sleds, but there is always been enough slop that the ends of a 4' board are not square. Close, but not square. I can get a 2'x2' piece square with the miter gauge ( my miter gauge has a 2' fence on it), but not 2'x4' pieces. The only issue then is the top and bottom of the sides, etc. This is where I make the crosscuts with a circular saw and then rip on the table saw.
I guess it's a matter of knowing one's limitations and developing techniques to get around them.
Bob
All crosscuts of the Pencil 12p can and will be done with my 10" Dewalt sliding compound mitre saw. Same applies for all critical crosscuts of the Super version, only two side panels are to long for the sliding compound mitre saw.
My issue is with the rip cuts on my contractor size Hatichi table saw, i don't trust it's 90º trueness. I may oversize them and use the router to true the cuts for butt joints.
Overkill but i'm thinking of using the biscuit joiner too in the assembly process.
Well, let's just say it was short a 1/16" in all the wrong areas. Hahaha! In situations like it, it's best to just step back, use the scraps for another project, and move on. Also, fortunately with having a panel saw I don't need to worry about any cross cuts as it's all automated and just about as accurate as my CNC router. Onto the next one!
You can use a tri-square/ framing square, to ensure the saw blade is @ 90 deg. to the table.
don
That's when you switch from manual to automatic and let it cut to size for you. I never use fully manual on my beam saw for this very reason Trim an edge and let automatic cut it to size for ya.
you might think I'm kidding, but if the sheets / cut parts aren't loaded square into the clamps, and the manufacturers' service reps can't get a technician to properly calibrate the side fence/ alignment rams or travel sensors, you're still at the mercy of the machine operator to catch the errors - true to dimension is one thing, but true to square on multiple cross cuts is rather another
yup, sometimes a decent table saw & rip fence are all ya need
Powertool dummy question - how is a sabre saw/jig saw for straight cuts of 3/4" and 1/2" material?
There are no dummy questions, but certainly some stupid answers.
With a well clamped straight edge and well locked in sharp blade you should be able to achieve a clean straight cut. I've never needed to, but I bet Bob has done his fair share on a balcony workshop.
Rather than biscuits, if have a decent enough router, I'd take the extra time to cleat the rear panel and machine rabbets into the other 5 panels - makes for a much more glue surface area and a very well braced enclosure than biscuits.
Remember one guy's "Overkill" in another's "sure I guess that'd be OK for a quick n dirty" 😉 These boxes definitely benefit from bracing, but it could be less elaborate than shown - those took longer to cut /fut than all the rest of the material for the boxes.
If you have a $100+ saber saw, you might get a clean accurate cut. When I was building speakers with a saber saw and hand tools, I always trued the cuts with a plane. Note that if you cut a curve with a saber saw, the blade will always lean to the outside of the curve. You cannot get a 90* cut with a saber saw.
I do use a saber saw quite regularly -- to rough out blanks to be finished on the router table.
Bob
You do have a bit of a "router fetish", yes? 😀
You might be surprised how far out of square the average framing square is. Especially for a 36" to 48" cut. Same for the average triangle. If the framing square was that accurate, you'd have square walls/corners in your house.
A framing square is used in this case to ensure the blade is @ 90 degrees to the table. The degree of error in such a short application is negligible. You can always check the square by scribing a line on some scrap,and reversing the square and checking again.
BTW, the (inside) corners of SOME rooms are out of square because typically, a heavier application of drywall mud is applied to the corners.
(damn drywallers!)
Best
don
Or not!
I have a 4' drywall square,of all things, that is dead on. I use it to set my circular saw fence for cutting 4'x8's. But as previously stated, you can easily check this by drawing a line and the go to the other side and repeat the line. (I think that the assumption that the sides of a 4'x8' are parallel is generally valid. DO NOT assume the the ends are square with the sides though!)
Bob
dammit man you made me snort out my coffee - the out of true/plumb/square of wall framing has less to do with the accuracy / sophistication of the measuring tools than with the care & attention of the trades person - same could be said for speaker enclosures .
agreed Bob, the circular "skill" saw would be my first choice over jig saw for bucking to size - actually with a decent blade an clamped straight edge, they can be as clean and accurate as a table saw - just more work on repetitive cuts - and certainly don't assume that "4x8 ft" wood sheet goods are square or even consistently exactly same in all 3 dimensions
as for drywallers / mudders - yup Don, those are a special breed alright - just try to keep them out of the same work space/time as a floor layer or electrician 😀
