manojtm.. what protection topology you use?(please describe it in a few words).Have you made o few hundred shorts all types(signal out clipping - short,signal out no clipping - short,no signal, short fallowed by input signal) without any transistor burning??
Ok...please tell me what aditional info you need....
Thank you for responding🙂.
The most important: control signals of gate driver. But the schematic, with test points shown, is also welcome.
+ : output signal and load, shorting method, output current before failure, the reason why you think the FET blown exactly in that moment, etc...
I prefer to know supply voltage also (measured by scope during failure).
Debugging a design needs almost every info a simulation needs.
Ok..i changed irf540z with irfb5615 and the rate of failure has decreased alot..i was unable to burn anything with more than 50 shorts.
Now i am using irfb4321 and making tests with them..
-supply voltage +-49 no load;
-shorting methods : output at or near clipping followed by short;short with no output followed by large input signal
-protection trip point 30A peak +-10%
Control signals before driver:
Low side control signals versus output after driver:
Protection versus output(short pulse...no failure with irfb4321)
...during failure of course. However the negative dead time shown by your waveform is also interesting, but not in this aspect.
5th picture is weird, can't figure out what it is.
Input signals (preferably every signals) should be measured relative to their gnd.
Protection: undeclared identifier.Protection versus output
Shorting method: I mean how do you make short? Piece of wires, or relay, or thiristor, etc...
I wouldn't test OCP by short. Testing with 1 or 2 ohms load and burst signal is much more informative, controllable, and safer. After this you can check real shorting.
It seems is it much harder to have failures with 150 volt rated transistors,as soon as i have another one i will post pictures.
I can not measure signals relative to their ground since i do not have isolated probes or scope🙁.
Picture 5 is low side mosfet signal after driver versus output during short.
Picture 6 is protection logic level(blue) versus switching bus.
I make shorts using a high amperage switch,1 ohm is normal load for me😀,i already tested with signal bursts.
Hi CPX,
i am not tested OCP with short.test with 2ohm load (spk)with high volume OCP circuit run perfectly no burns
change OCP sensing delay to 0.5uS
But you can, differential mode with 2ch.It seems is it much harder to have failures with 150 volt rated transistors,as soon as i have another one i will post pictures.
Yes..but for only one signal at a time....🙁But you can, differential mode with 2ch.
you can't do much, if you have floating signal... other option is look every signal compared to ground... if is not bad really, since you know what levels should at test pointsYes..but for only one signal at a time....🙁
Hi CPX,
Since i am not using your protection i can not change anything..my reaction time since event to total shutdown is around 3us.
Hi All
I am ready to sell my UCD AMP
1. carrier based Class D Amp
2. self oscillated based Class D Amp
anybody interested pls replay
Hi CPX
I will give you the Equation for overcurrent Protection
550mV/.04R = 13.8A
you want to increase the current
550mV/.04R * 1K5+1K/1K = 34A
RGDS
MANOJ
550mV/.04R = 13.8A
RGDS
MANOJ
Hi All
again i have one doubt, Everybody says that for IR2110 MOSFET drive 100nC for 2A
The equation says 1C=1A/sec. then how 100nC=2A???
RGDS
MANOJ
RGDS
MANOJ
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
