still no progress on my SR 🙁, i have to finish my other project firstHi Naf...
How is your SR progress ? I am looking forward to hear about it..You won't be disappointed
Mr Mile Apex or anyone else, if you have a little time you can correct this regulator I did not change anything except the component layout.
Nice PCB, just use separete layout tracks from 0,22R to cap pins and from output to caps.
thanks Apex, if I could use this PCB? whether there are any lines in the correction please, thank you.
You can use this pcb without any correction.
HI.whats the difference between these two amplifiers concerning sound quality? SR50 and SR100?
Leonatax,can you post the pcb for SR50?
PSU SRA APEX
Mile before I have to thank to all of us share the schematic.
allow me to deliver a new layout for the PSU SRA APEX, may be useful for us all.
PCB unit is a Millimeter.
thank you
Munthe by Damanhuri
thank you
Munthe by Damanhuri
First I want to Say Thanks to ApexAudio and all the STARS that keep woking on the PCBs and more.
I am going to build a stereo amp for my new Wharfdale Diamond 10.1 (100W), hoping they will
sound nice, havent heard them play yet.
I first looked at the AX series amp then found my way to this thread,
sounds like SR amp is more power and great sounding, maybe better than AX ?
As usual i got so lost trying to establish which ver of ciruit and pcb to use.
Apexaudio can you pls help me in the right direction as which pcb to build.
Ill post all pics of build as it progresses, Im hoping for a high quality build.
Id reallyn appreciate the help.
I've remove wire jumper in the bottom side.
Will the bottom foil pattern come-up?..😀
I like your design rectangular yet compact I figure the output transistors are well spaced on the heatsink.
Nice work!
Hi! Mile
can i use this type of piezo tweeter with sr200 directly? or i need to add a capacitor in series with it please help me
Ahuja Sound Solutions
Thank you
Thank you
Hi! Mile
Thank you
Use 220nF/250V capacitor in series with it
Then what will be the cutoff frequency?
Im in the process of making 2x SR200 pcb's, with "Press 'n Peel" transfer method,
fingers crossed.
I have my pair of
Product - Products - Wharfedale Hi-Fi
sitting in my room now for 3 days, im dying to hear them,
going to connect them to my chipamp this weekend,
Does anyone have experience with these speakers and how do you think theyll match
with the SR200 amps?
They small and compact, its very small where I live and I only have a bedroom to myself.
So I thought they would be nice
How many output pairs should I use and what Supply Voltage.
fingers crossed.
I have my pair of
Those heatsinks are nowhere near big enough, and there are no holes that i can see for air to enter the box, that fan wont be doing anything useful.
Whatever the manufacturer tells you it is.what are the voltage rating of all non polarised capacitors ?
- Studio Reference Amplifier
