900W H-class PA Amp with Limiter
hi apex sir , thanks for the reply.
now i include the 10k pot.
if u don't mind, pls check the hole pcb layout and tell me is it correct or anything wrong.
Use 1k pot (or without pot) with MJE340 for Q5 (Vbe multiplayer bias transistor). 10k pot use with darlington for Q5 (like BD681...) i dont know which post is thats schematics.
schematic of b500 tef use for reference to h900 tef add limiter as per sir miles this schematic is correct according to sir miles
regards
hi apex sir,
for the PA , with 4pairs, what is the maximum voltage for 2ohm load? (75vdc-35vdc-0 or 80vdc-40vdc-0), which one u suggest? i need a accurate value for this.
how much power it can deliver into 8ohm,4ohm,2ohm?
what are the transformer VA rating, need for stereo?
I'm expecting Ur reply sir.
Hi apex
thanks for H900 design..
can you prepare some table like the ones I attached ? that is for quasi nmos350 + (power rating of transformer and obviously lines current).
also i have another question from H900 performances , how is H900 DC-Offset ? for example in nmos350 we can adjust some variable resistor to minimize DC-Offset.
Hi apex
B500 and H900 use OP amp for DC servo, no need to adjust DC offset.
