Hi soundhead,
FUY, Here is an example of a single folded T-TQWT not tuned to low for outdoor use:
b![]()
Thanks Bjorno this single folded looks good.
Agree, Not that large...~45.5" high (if 18mm wood).
What is your application besides being used outdoors?
b
I will be playing R&b,hip hop and pop music.
The next hard part is to find someone to fold it up for me.
Cut the HR layout in half(=112 cm internal height) and locate the terminus S4 at the bottom of the enclosure facing rotated 90 degrees (S4= a rectangular opening of 46 x 8.78 cm^2).
I calculated with a very narrow internal width of 46 cm and driver should be located at fitting snugly touching the bottom plate . The box external width would be at minimum~46 +2 x 1.8 cm= ~19.53".
b
b![]()
I am not that smart when it comes on to maths be I will try to figure it out.
...I am not that smart when it comes on to maths be I will try to figure it out...
Hi Soundhead,
A few more hints:
b
PS: If you are 'off' a quarter of an inch on any dimension: IMO/IME, This wouldn't cause noticeable differences on the performance.
...Can four of this cabinet hit 135db outdoor...
This will depend on the system space load :
b
If you're open to a TH design and a little more work, this should achieve the output and extension you're after: 18TBX100 TH by epa
..What can be done to get 135db outdoor 2.0pi..
Add some more speakers ...6 T-TQWT's(6 Ohm system impedance(5.33 Ohm)) in total 2S x 3P... + 2400W-amp or Eg=120 VRms.
..Will a longer horn work..
Not necessarily longer but larger, not if a T-TQWT is using only one driver/box.
b
Tapped horn was my first bet but too complex to build.
b![]()
How much more larger the box will be.
As large as necessary without screwing up the passband FR or phase, of course.
At first hand:I never sub-optimize speakers by chasing SPL or Power,actually in my world all other parameters involved comes first as being more important.
SPL and Power is simple: Just add more speakers...
b
- Subwoofers
- B&C 18tbx100 T-tqwt
