Hifimediy direct out cs4398 DAC
Hello
I did that but it isn't working ?
What's happened ?
Sorry the pictures arrive.
I tought the ground on the cs4398 and not on the rca, that's why.
So, very clear but a lot of hum in the 2441 and the 2405. A bit of compression too and distorsion.. I used intertechnik zn cap 1.5uF and russion pio 220nF in parallel.
What's the solution to reduce the noise first ? I'll see later if I keep this solution or no.
Bye
On my amp (carver pm 1.5) I measured the ohmic value between xlr ground and earth ground : 27kohms.
The dac works when the rca ground isn't on the earth ground of it, so on the ground of the input amp's xlr.
May be shouldn't I use the earth ground on the dac ?
Is that a prototype of a new product ? With those empty pads, it will be a tweaker's playground.
It will be great if it can have TI or AD SRC chip. And why 2 optical port ?
Right~
I think no problem to use other SRC chips. And there might be a DSD input and up to 8 S/PDIF inputs. so a added optical port is placed because there is still some room.
Yubing
please help! my dac will not power up and the dac heats up very hot....the led that indicates lock does not light up.....im still getting 5 volts from the regulator. i bypassed all the electrolytics on the main board and was still playing music then i put in a tube output stage then suddenly the dac will not light up...
please help.....thnks
