Are any of those plans for the FR88EX applicable to the FR88 (not EX)?
From the title page of plan set document:
while at approx $13 each the FE85 is approx 1/3 the cost of FR88Ex* and would make a logical candidate for a first time build, don't expect much SPL or bass from the smaller driver without HP and woofer supportDesigned for the FR88ex since we had a case at hand, they should all work with variations such as the FR89ex, FE85, and FR88, the quarter-wave designs having a greater level of tolerance.
If you try them, do let us know.
* I couldn't find a current listing of availability for the FR88 at either of the primary North American resellers - if still in production and available internationally, the freight, duty & brokerage/documentation fees could well double their cost, thereby negating any advantage it might possibly offer. Also note the Ex has 10Hz lower Fs and 3 times rated excursion over the FR88 - performance factors that can't hurt.
Unfortunately or not, the overwhelming prevalence of non CRT video displays has resulted in a dearth of shielded / low magnetic flux driver, so if that's a critical matter, your choices my be limited.
I use the G115 die-cast aluminium boxes (two attached together and drilled through), which have frontal dimensions of 105x145mm Do have a little baffle step compensation filter in there of 1,5mH and iirc 3,9R... Don't ask me why, but these values were what I had laying around... Still work in progress...
Further the notch consists of 6,8R mox, 8,2uF mylar and 0,5mH low resistance ferrite core inductors.
Very nice design! With this very narrow baffle, I guess you will only have to control the rising frequency response. I think that 0,33mH//8.2uF//4,7ohm would works fine. I would first work in the tonal balance. I think you will not need the BSC filter. But your ears are the judge
One interesting thing that I noticed in the implementation of the notch filters in fullrange designs (small fullranges) is that they are generally centred at around 3kHz. The play better but don't actually corresponds to the more linear response in on axis single measurement. I suspect there is something about this frequency that our brain don’t agree with measurements
Been playing around with the FR89EX some more and it seems these need a lower notch filter, the 1K frequencies seem to stick out more. These might need a pretty wide filter though, centered at 1.5K. Testing facilities are a bit limited right now since I have the speakers at home now, at work I can first EQ them without the notch filter to determine what it should move towards...
The BSC filter did seem to improve things, but as long as the notch isn't fully tuned right I can't really judge the BSC filter.
Funny thing was yesterday I built two more boxes with FR89EX by replacing the FR88EX I had in these cabinets and at first I heard a little rattling noise at higher outputs. Turned out the cones were hitting the grille, whereas with the FR88EX it was fine! They DO seem to move much much more!
Not necessarily a good thing, right?
Might be true indeed, it might be my lack of experience with these, but so far the 88 seems to have the edge in sound quality. Especially voices with the 89 seem far to close and the same notch as I use on the 88 doesn't seem to tame that with the 89..... It seems to be the lower vocal range sticking out too much, hence my suspicion the notch should have a lower centre frequency.
Funny that the on axis frequency response graph they publish on the two drivers seems much alike....
Even though I posted this in another thread I think this link belongs here too The Serene Audio Talisman Computer Speaker | InnerFidelity as I think these speakers are using the FR89EX which seems to come in 2 variations 4 and 8 ohm.
Inside the review there is BTW a nice link about nearfield listening.
Interesting! Well Fountek also have the K3 design off the shelve and the description claims they use a two band fixed EQ. Looking at the pic I can only conclude from the components I see on there that they use two notch filters (LRC-LRC)...
Products_Fountek Electronics Co.,Ltd
It would be nice to know what they use on there....
Dave has a plan-set for the little FR88EX
http://www.diyaudio.com/forums/full-range/210106-fountek-five-fr88ex.html
dave
I emailed Fountek to see if the would tell me the component values used in the K3. Never got a response. They did publish the values used for the FR135-ex.
http://www.madisound.com/pdf/FR135EX-Encl.pdf
I'm working on my own filter. I don't like the sound of this driver without a filter...and a sub.
Had not seen that, good work!!
![spin :spin: :spin:](https://files.diyaudio.com/forums/images/smilies/spin.gif)
Oh yes, very pleasant now. Just finished with a beta version of a notch filter, which may be a bit exaggerated, but pleasant, oh so pleasant!
Just amazing how it appears to clean up the high range, just by suppressing the midrange....![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
FR89EX so far:
Two notches, from amp to speaker first one: 10uF-5R-220uH, second one 10uF-20R-220uH...
Some finetuning to do, didn't have many other values at hand now to play with, but this is definitely worthwhile!
FR89EX so far:
I'm glad I have a pair of Avalon mixing monitors here as a reference, which helps a lot to tweak the sound, they couldn't be more alike, I guess I am running in to physical limitations now LOL! There appears to actually be air now in the highs, and vocals are just incredibly pleasant, I have some wires here to short the filters with and it just goes from yuck to ahhhhhh!
what now, which one is better 88 or 89?![]()
Now I am running ahead in tweaking the 89, the 88 needs some more work before I can really go for a shootout... The 88 seemed best when untweaked, but the bass capabilities of the 89 have are now revealing more, and perhaps that will eventually outperform the 88 overall....
Too early to tell..
MAN I can play loud now without irritations!!
another build with the fr88ex incl. notch.
lol, this is making me crap my pants. I used google translate and found that they had a plan with the Omnes Audio BB3.AL which I read is the same as the Veravox 3X. I found the link to the plans. Now maybe I won't have to figure out the dimensions of the cab and I have details of a notch filter. cool
from what i read, the veravox3 is somewhat differt to the bb3.al.
someone build this fast
VeraTwo
with the bb3.al instead of the veravox3 and then one bb3 got damaged by his daughter. He found a pair of veravox3 to replace the damaged bb3 and wrote about the speakers now sounding better. (xover was designed for veravox)
VeraTwo
- Full Range
- Fountek FR88-EX
