Aleph 30 the best choice of C1 C2 C3 on brian gt PCB
The same schemo as in post #1 in this thread. BrianGT PCB's. +/- voltage is about 13.8V. Outputs are IRFP240's running about 1.2A bias.
Mods so far: C1 and R10 removed, R14 and R16 reduced to 866R, C2 bypassed with .12uf MKP film.....
about 20Vp-p. The amp clips with a sine wave at about 22Vp-p so just under clipping. The sq wave still has ringing at lower p-p voltages as well, although at lower voltages it has slightly less ringing. The pic is at 10Vp-p.
Would ferrites somewhere possibly help?
Hi!Which is the maximum undistorted output signal with a sinusoidal input signal?
The output load is 4 ohms or 8 ohms?
Can you post the picture of the oscilloscope?
As I say this because in my first mini aleph powered with +18 V 0-18V I made ​​a mistake, I used the 0.33-ohm resistors instead of 0.47 ohms, the result was a distortion early at about 7w of power output.
I do not know if this information will be useful for you but i hope this.😉
this thread is getting more interesting ... thanks to ZM that is always available to answer our questions.
you have 2 of 1nF there ; C102 and C105
in same places
Do you know what are C102 and C105, why in BrianGT pcb there isn't C105?
C104 from 10pf to 15pf ?I imagine it could affect the frequency response!
If yes how to determine the right value?
hmmm...This caps are objects always the most mysterious!
This thread is getting more interesting ... thanks to ZM that is always available to answer our questions.
Thanks.
22Vp-p
I'm using an 8R 100W load resistor
I have .47R source R's and clipping with a sine wave occurs at about 22Vp-p (about 8W or so) I'm assuming that this is reasonable with +/- 13.8V rails.
Bingo!!
OK, that made a big difference. I paralleled another 10pf with C4 for a total of 20pf.
I'm starting to understand.......R15 is the feedback R and C4 is the compensation cap, correct? Now I want to play with reducing feedback........😀
So my new square wave would indicate a bit of HF loss, correct? Leading edge is a little rounded. Looks like for 100K feedback R, the optimum C is somewhere between 10 and 20pf. Of course my pf cap selection is a bit thin.....
Thanks ZM!!
Thanks ZM!!
Hi! BW do you think that you will try with 15pF or not?
