Variation on the JC-2 preamplifier
Yes, there are basically 4 resistors and a trimpot that set the currents on the JC-2, and every version I have seen, starting from the "original" one (JC could say if it is indeed the original) until the last one seem to be different.
So it's difficult to say which to go for. The circuit being a folded cascode makes it even more difficult.
Reducing currents in order to get things cooler might be better for the parts, but certainly not for the audio performance.
Should I go back to the original values (100 & 20 ohms)?
The JC-2 clone apparently choose approximately what Borbely used on his EB604 (post #45): 1K5 & 332 ohms. But EB's second stage were jfets, so currents should be small, me thinks.
Where do I start?
I kind of went trough the same problem, too much information and too many schematics and variants of the JC-2. It came down to tubeshunter and jim's_audio on eBay. Then it came down to the eBay feedback score. Maybe this helps.
Some comments from Mr Curl should throw some light over this resistor dilemma.
On post #157 he says that there should be at least 1.5v across the load resistors, and suggests at least 150 ohms instead of 100 for the Toshiba Fets.
So the question now turns to the emitter resistors on the output stage, which are part of the folded cascode too.
There are also two trimpots that need setting too, which should be explained on the kit.
Here is the schematic from Jim's Audio JC-2 kit. It is an outstanding sounding preamp, it is currently in use with a Parasound HCA-800II power amp, which I think is another of Mr. Curl's designs.
attachment.php
Which FETs are used in the actual circuit ? The current through them appears to be 1.3 - 2 mA (a bit on low side, but probably chosen to allow for a wide range of FET grades).
The current of the output stage seems to be somewhere between 12 and 20 mA, which is OK IMHO.
2V to 3V of Vdrop across that 1k5 gives a total current in the output+jFETs of ~14mA to 24mA.
If the Left side jFET currents are only 1.3mA to 2mA, then the output stage currents are in the range 12.7mA to 22mA.
It looks like LR5 value needs a lot of experimenting. That may result in LR2 dropping a bit.
Hi there,
The kit is carried by us.
I am a bit awkward to respond on a non-commercial thread but hope a short reply can facilitate the discussion.
We are using matched 2SK246BL and 2SJ103BL. Idss between 6mA to 8mA are selected. Same type matching is good to 3%. Complementary type matching is about 10%.
There's a quite similar thread discussing the JC-2 preamp, where I'm rising other questions:
http://www.diyaudio.com/forums/solid-state/10160-need-build-jc-2-preamp-37.html#post2884040
These are not threads opened by me, so I can't ask to join them. But I also do not want to ask similar questions for the JC-2 preamp on both threads.
This thread seems to be concentrated right now on the Line Amp. But I think the other one is also considering the whole preamp project, including external parts (never mentioned here) and a phono preamp.
The parts I'm talking about are here around the Output Amp.
On the newer JC-2 versions there is LR01 (3K3) and LR4 (10K), which are the gain resistors. On the original JC-2 those gain parts were external, involving a balance switch and also a 2uF capacitor.
Should we disregard those parts on this project?
Good to hear you are impressed... Soon I will build mine starting from a kit...but also have a layout to use the venerable Toshiba 2SK389 and 2SJ109 at the input plus other Toshiba's on the output. The layout includes cap multipliers for each polarity on each channel, as per JC suggestions.
I have all the transistors etc except the PCB which I'm a bit lazy to etch.
cheers, Tony
