Isobaric - less then $20
New Pics
I hope this works :xeye:
I get :hypno1: looking at it;optical illusion, but it is square.
The woofers are suppose to cancel out something...Oliver will tell us.
Curious if a straight box has an advantage over a pin-ball machine design????
Btw, It was not hard to build. On a 1 -10 scale, I'd give it a 4. About $60 into this.
They sound nice, go deeper than expected, not hard hitting, more of a "soft" bass; very easy to listen too........
Yes - more good ideas. I've looked at both those areas a couple of times Will do.
with my current setup at the moment my book shelf speaker (q acoustics 2020i) will bottom out before my subs do, meaning i cant turn it up as much, is there anyway of cutting the low frequencies of to my bookshelf speakers without doing the same to my subs ?
2009thread1
..is there anyway of cutting the low frequencies of to my bookshelf speakers without doing the same to my subs ?..
Why not just plug the ports on your box-shelf's. Start testing with a filling that do not produce a wheezing sound..This would move the f-3dB up to a better integrating point and protect the driver from over-excursion.
BTW. I thought you have built a T-TQWT...Do you have any simulation script of your TL?
b🙂
BTW....I watched the 1/2 hour of original Ghost Rider last night. The voulume was louder than I though and it about threw me out of the chair when it got going....the system roars like a lion.
The mini 6.5" don't sound mini (using 8)
Sounds like you need a active crossover.
You'll have to go intot more detail on your equipment on hand (or willing to buy).
Never bottom out speakers :-\
my stereo amplifier is a denon pma710ae, with the q acoustics 2020 bookshelf speakers, and ixos champagne speaker cable, the subwoofer amplifier is a pa amp i bought for £110 which is 250 watts rms two channels, 500 total.
i never bottom them out but the subs will reach half excursion when the bookshelfs are as loud as i'll push them
