8 channel amp based on the LM4780 ICs, but I am begining to think I should have gotten bigger toroidals, even though I haven't made anything yet.. lol
My towers still aren't finished... I kinda work in stages... work on something for a few months, then find something else....
I also have half a car amp... one day, maybe, it will be useable.. lol
Oh Building things! Sorry, I'm working on a analog meter power monitor and power switcher. But it's sporadic. Porjectus interruptus. At the rate assembling a working audio system is going it may be spring. I fried the woofers in one of my Prodigies last night. So fixing that is the project first at hand. This evening I've been searching the archives and catalogs thinking of doing a dipole line array.
eStatic
eStatic
Re: dipole line array
Have you checked out these little 3" Aurasound drivers?
NS3-193-8A
SY said:That's exactly what I've been wanting to do to take the midbass load off of my ESLs. I'm envisioning a stack of 15 or 16 drivers in the 4 or 5 inch range to run from about 70 Hz up to 300-400. All integrated into a nice column that contains the ESLs.
NS3-193-8A
Uh...nothing audio at the moment... I got hotter things frying...
http://webpages.charter.net/dawill/tmoranwms/Casting_Rvb3.html
Tim
Tim
SY: Are you speaking of your Acoustats and if so what size are they. Mine were 2+2, I think. Two tall, two wide. They were and loud and clean but I XOvered at 225 Hz. Did not image to my liking at all though.
I sit as close to the orchestra as I can. I like big music big. So I'm toying with the idea of selling the Prodigies and building a "full range dipolar line array." Would sure like to hear one first. I like my chamber music as exquisitely clean as it is through my ESLs.
eStatic
eStatic
Over the last day or so I built a 5 opamp cct that is 600Hz lpf -> full wave rect -> 1Hz lpf so I can use my multimeter on 2v DC range to measure AC millivolts. Playing around a lot measuring Thiele/Small parameters on cheap, crummy speakers.
As always, things that look simple are not.
eStatic said:SY: Are you speaking of your Acoustats and if so what size are they.
eStatic
These are Acoustat stators set up in a 1+1 array. I've changed the diaphragms and coatings, changed the interface to a single transformer and passive line-level EQ, and built a frame with "wings" to get some free midbass extension.
Re: Re: dipole line array
Nice specs, the Q in the right range, but since I need 32 of them, they're priced higher than I was looking for. I don't really need good midrange performance since they're getting chopped off pretty steeply at 300 Hz or so.
- General Interest
- Everything Else
- Whats everybody working at???
