I would unsolder and measure all transistors in power amp section, especialy drivers.
Oh my god! If they are faulty 😱
any short circuit in the drivers or leak will result in Dc offset in the output and that also can be measured at all times since there is no output relay and or DC protection of any kind ( already done )
so Goran this is out of the question
Doesnt have to be a short circuit in the drivers, drivers can be damaged in a way that there wont be a current flow, they could be open.
OK, well, the -24V on the schematic means there should be 24v across the relay. So, if you measure volts across the relay coil pins, you should see 24v. That is of course, when Q639 is switched on. If it is higher than this, you may want to replace R698 with a higher value.
Anyway, we are getting ahead of ourselves. First, you should see if the power amp works at all. To test this, i would simply jumper the relay pins, and check out the power amp. Be sure to use an unimportant pair of speakers. If the power amp has other faults such as blown outputs, then you may as well stop.
I am measuring 0 volts across the coil. As I understand either Q639 is faulty or there is something else wrong in the circuit holding back Q639 to switch through.
I am very nervous to jumper the relay pins and on top I can't find the speaker I used for test purposes, looks like it disapperared to the garbage...argh!
But thank you all so far, I will report back when I got a test speaker.
It doesn't make sense to change Q639 at the moment, hmmm?
Not before you haven't measured the voltage across R697 (in parallel to Q639 B-E, as you've certainly noticed).It doesn't make sense to change Q639 at the moment, hmmm?
This should be approximately (-)0.74 V with the relay engaged. If it is (or is even higher), Q639 is dead. If it's below 0.4 V or so, the fault is elsewhere. Probe for about -5.7 V on R692 / D651 then.
And I repeat, there is no classic protection circuitry here, only delayed turn-on that requires nothing but supplies to be present. The only kind of power amp protection is an output fuse that'll hopefully prevent a speaker voice coil from going up in smoke.
If you don't want to risk a speaker, you can just measure the output voltage with the relay jumpered over. You should have no more than 50mV DC on the speaker terminals with no signal.
If you then apply a 50Hz sine wave to the input, your multimeter on AC should measure a corresponding voltage. How much depends on the gain of the power amp, and of course the setting of the volume control.
If you measure any large amount of DC at the output, then something is wrong.
You could also use a cheap pair of headphones plugged into the Headphone socket - the headphones are driven from the power amp output, via a resistor to drop the level down.
Good news:
With relay jumpered no smoke 😀
But:
I am measuring DC at the output 200mv on one side, 280mv on the other side 😡
Good news:
When I put testtone I am getting a signal out of the speaker 🙂
Bad news: it distorts very fast when i crank up the volume...
But:
Good news:
Across R697 I am measuring no voltage.
R692 / D651 I am measuring no voltage.
Good news:
But:
Good news:
Hm, so there is a problem. If you have some 10uF capacitors, try swapping out C601/C602. Signal coupling electrolytics have a habit of going bad and causing distortion
That's why Q639 doesn't do anything.Across R697 I am measuring no voltage.
Is the R692/D651 junction exactly at 0 V or more like -0.2 V? That would make the difference between a Q638 that's dead short (or a shorted C652) and one that merely is doing its job.
What's the voltage at the R694/R696/D652 junction? It should be positive to -0.6 V, a value of about -1.0..1.2 V would indicate that Q638 rightfully turned on. If that should be OK, you can temporarily remove C652.
The DC offset and amplifier "performance" indicate that there must be more amiss, unfortunately. 🙁
But since both channels are equally affected, this could be a bad connection of +/-B1 supplies and ground from the power supply to the power amp. Should be easy to probe with the unit off. Could it be that the amp has been dropped or otherwise handled roughly?
I am measuring the following (with relay jumpered):
R692/D651 = 9 mvolt
R694/R696/D652 = 1,2 volt
ground seems ok
+/-B1 also
The sound is ok with my headphone, my testspeaker is bad - sorry for my fault, not checking this better before
Still more then 200 mv DC at the speaker output after exchange of the caps😡
That's MINUS 1.2 V, I suppose? That would explain why the relay driver circuit does not engage.I am measuring the following (with relay jumpered):
R692/D651 = 9 mvolt
What do you measure on the other ends of R694 and R696? I have a hunch that the indicated 36 V may be quite a bit low.
You said the thermistor measured 70k. That should be OK, it's a nominally 50 kOhm part, NTC. As it warms up, its resistance reduces, thereby shifting voltage at R694/R696/D652 into negative territory until eventually (overtemperature condition) Q638 starts conducting and thus turns off Q639.
How much can you influence this by turning the input stage balance adjust pot, VR603?Still more then 200 mv DC at the speaker output after exchange of the caps😡
This design is a little strange. First of all it seems to be an inverting amplifier at a gain of only about 22 dB?! Input resistance is somewhere between about 5k and 20k depending on volume.
Input pair balance is very odd - DC resistances at the bases are deliberately imbalanced (with an offset control provided to get output offset in check), at signal frequencies impedances become approximately balanced. Whoever designed these Rotels had a penchant for very strange design decisions at times (I once helped a guy mod his RA-980BX for much reduced noise, turns out they used a rather noisy AD712 opamp after the volume control).
thats not MINUS
around 12 VWhat do you measure on the other ends of R694 and R696? I have a hunch that the indicated 36 V may be quite a bit low.
I measure the thermistor again, its 56k
not enough, but I can influence the DCHow much can you influence this by turning the input stage balance adjust pot, VR603?
well, this doesn't mean much to me, as I don't understand it 😱
Can you tell me what disadvantage this DC offset has?
Ok, after I found out that my multimeters plus and minus inputs were exchanged 😱 I can verify the voltage at R694/R696/D652 = 1,2 volt.
The DC on the speaker terminals is going down from 270 mV to 190 mV on one side.
On the other side its going down from 200 mV to 116 mV.
This has been measured after the amp has been running for about 20 minutes.
But thats still too much. After reading for some time in the web I assume that its possible drivers are bad...
Hmm.thats not MINUS
What do you measure across R695?
The transistors are both original 2SA608K?
Now that doesn't sound right at all. The voltage on the other end of R696 should be +36 V (maybe +33 V here), and R694 goes to the thermistor, and with the thermistor value you determined, its other end should be at -2..-3 V or so.around 12 V
Verify function of D609 in off state (diode test in both directions), and measure the voltage at its cathode (should be same as one end of R696 - if it isn't, there must be a bad solder joint at work).
If the diode looks fine but the voltage still stays at +12V instead of +33V, try swapping in a new electrolytic for C653 (10µ / 50V or higher).
That'll need further investigation then. Looks like loop gain is very low - at least that's the only explanation I can come up with. But before we get to this, let's sort out the relay problem first.not enough, but I can influence the DC
Yes it is Minus, see my post above 😱
What do you measure across R695? 0,6 Volt
No, they are AC698KF8G, and if I look at the other transistors, guess what: they also don't match the ones from the schematic 😡
From ground to R694 I measure almost 30 V and MINUS 1,2 V
Diode is ok, voltage at its cathode is 0 V anode is almost 30 V.
I have done this already...
Yes please 🙂
They appear to be doing their job in any case.The transistors are both original 2SA608K?
What other kinds of discrepancies did you notice?
I suppose you meant R696? Wouldn't make sense otherwise.From ground to R694 I measure almost 30 V and MINUS 1,2 V
If everything were OK, those -1.2 V should be something like +14 V. The thermistor would have to go down to about 1k for the relay driver to turn off.
Please check the values of R696 and R694. The only explanation I have now is R696 being way out of spec (high).
YEAH!
It turned out that R696 was faulty. After I exchanged it, the relay works 🙂 🙂 🙂
Thank you so much for your guidance and patience!
I still have to get the DC on speaker output down...
Could it be that the power supply electrolytics are bad after 20 years? They are Rubycons 85 degree
- ROTEL RA-820BX3 not working
