I have ordered two large Multipower batteries, and give them a try the next weeks.
Forget the batteries. Better try regulated power supplies. They are making the amp sounding much more liquid.
what types of regs are you recommending?
Have you tried different feedback resitors?
Sam
I used active capacitance multipliers with negative feedback. The French magazine L'Audiophile had published an interesting design in the 1980ies.
Give me your email address and I'll send the schematics.
No, I've never tried different feedback resistors.
Hi Georg permaneder,
is it this:
http://www.diyaudio.com/forums/solid-state/5462-hiraga-le-monstre-2.html#post55559
A lot of my DIY friends in Munich around 1990 had this kind of power supply for their Hiraga LeMonstre, and favoured it over battery drive and also over monster electrolytic power supply.
best regards,
Hartmut
is it this:
best regards,
Hartmut
Hi Hartmut,
I know. It was in the late eighties or early nineties when I brought the schematics and a pair of Hiraga 30W A with regulated power supplies to a listening session to Mirek and Wolfgang.
Probably this could have been the initialisation of building regulated Monstre and Hiraga in Munich... Here in Bamberg, dozens each of both amps with regulated supplies from that time are still running.
Georg
Georg
i can remember having both, capacity multiplier and Batteries, buffered with more than 1F Capacitance on my LeMonstres. Batteries had no sonic benefits over the Capacitance Multiplier.
With a capacity multiplier the amp sees much more capacity than you could afford in real capacitors.
AND, when driving Monstres with higher bias, you have to recharge the Batteries every Day.
AND - DONT use Lead Acid Batteries inside rooms!
I remember Hirag writing that the batteries are not for bass (there is enough bass, with the cap multiplier it is straight from 2-400kHz); no:
the batteries and the supercapacitors are there to create the very very low level ambience realistically.
I have the supercapas not the batteries though.
I once saw an airplane battery, these are totally sealed (no corrosion in an airplane) so safe in a home.
albert
albert
Here are the schematics. The circuit can easily be adjusted to any desired voltages by matching two devices per rail.
Where does this schematic come from? I Could not find it in L'Audiophile!
Thanks,
jp
Thanks,
jp
Itv is actually in nr 19 of february 1992.
Too bad it is one of the very few volumes I missed. Thanks anyway!
Does anyone have tried this?
WIMA Double-Layer SuperCap Capacitors and Modules
Jp
Jp
Nr.19 is February 1981; I checked but the article is not in nr. 19, and not to be found in one of the other issues as well. Mystery
Avond Pieter,
I think (& I found): N° 19 (nouvelle série) 15 anée N°62 février 92 (55F) lire Français ...
I wish a good lecture ... et bonne chance ...
I sent a copy-scan to J-P,
Allez, salukes,
Karel
Ook goedendag Karel,
Ah it's the new series; I was checking the old series which I have completely, but of the new series I just own some, not all.
Could you send me a copy-scan of the article as well?
The drawing is by Pierre Johannet when I am right.
Groet,
Pieter
Hi, hi ...
I do it stande pede .... (dus:direct) ... @ your "p" adres, please (via PM)
Nice to read you ...
Allez, salukes ...
Karel
Hi, hi ...
Allez, salukes ...
Karel
PM sent.
Groet,
Pieter
Correct (nouvelle série). I built a version of his balanced Kaneda amp a decade ago. Horribly I got one channel working the other I had something wrong in my self made PCB's.
The powersupply that was mentioned before - had me blow the main fuse of our house I built it with 2 x 25 Amp FETs; just a bit too much. I had not given it a slow start.
I remember now why the power supply bounced and oscillated heavily: I had as section after the supply, 56.000 muF capacitors. That is why they were completely opened up to maximum conductivity. The schema has 8 muF and a formal stopper resistor even to reduce the output current. I should try it again that way!
albert
albert
- Hiraga "Le Monstre"
