What voltage and current did you get ?
How even is it wthout the trimmers ?
I haven't measured it yet just listening...I have only just completed the mod
So I will measure it as soon as I get a chance (work getting in the way)..
M. Gregg
How´s first impression ?
It's very loud..
With two heaters on it's a bit much to stand in front of the speakers...I am also concerned about damage to the speakers the cones are being driven quite hard... at these volumes...YMMV
sound is clear and powerfull...its a bit early to tell yet it needs to burn in.. 🙂
I'm only using the mozener as a clamp....so the heat will be less spread across the resistor and FET.. cap still in place at the moment...
I don't want to use the trim pot its another pain in the ....like fixed bias..
😀...it's almost cheating....so I might change a few resistors to get it close..LOL
M. Gregg
Its interesting,
I think I prefer the sound of one heater ....wonder why ...sound is smoother and perhaps warmer..triode sound comes to mind...
Anyway I will do some tests when I get chance..
M. Gregg
M. Gregg
Thinking,
I have the zener voltage set so with one heater its not in conduction at idle..
With two heaters its in conduction at idle by a couple of volts..
Perhaps that is the difference.. 🙂
M. Gregg
M. Gregg
The mozener,
Does clamp the cap voltage and prevents the increase of cap voltage when two heaters are switched in... << just an observation 🙂
The only thing I can think of is my speakers must drive well with just a few watts.. I have no other explanation...
M. Gregg
M. Gregg
You´re only benefitting from the constant voltage when running it hard.
At low OP it should perform the same as katodbias.
I agree ,,if the voltage across the cap was to remain the same ie change with number of heaters running... 40v (one heater) 46V(two heaters)<<<resistor bias
If the voltage across the cap/resistor remains the same voltage more current must be flowing through the FET to reduce the voltage across the resistor?
This must effect the bias at idle?
M. Gregg
When running amp at low power you´re in class A.
When running it harder towards AB the mozener keeps bias from drifting giving less distorsion.
This does does show..the amp is cleaner much futher up the volume scale.. 🙂
Its a bit to far for my speakers ..... 😀
M. Gregg
What are the ratings of the speakers ?
You´re only putting out ~10W.
I think they are 20W..I know they should be OK...Its just the bass really moves the cones.. 😀
Not sure if these are exactly the same generation but very close ..
http://www.madisoundspeakerstore.co...rkaudio-alpair-7-gen3-grey-cone-4-full-range/
M. Gregg
Yes it´s a big difference in current available for driving the bass.
A transformer based amp has less in the lower region.
I expect my new PSU to give even better result.
Worth remembering the Impedance presented to the amp by the speaker at or near its freq of resonance, --for the Alpair 7 70 Hz, its many times the DC or quoted nominal impedance...
For the Alpair, its approaching something like 50 ohms at 70 Hz, therefore an easier load for the amp and more effective power can be realised.....😱
The only trouble is..
When you power them for the first time you can only have them at transistor radio volumes (I have a feeling you would damage them if you try to push them their so tight) and they produce what sounds like "0" bass...Then a very slow break in period over 6 Months..LOL
Then your stuffing polyfluff in the vent to reduce the bass...cuz its so loud..LOL 😀 😀
M. Gregg
OK just an update,
The toroids now have cork pads under the rubber pads made from cork tiles..
Result reduced Tx noise (mechanical).. 🙂
(Tx under rated no heat issue)
The 0.22 interstage cap was changed just for a laugh to Obbligato 630V <<(seem to like violin don't know why)
I would never have tried them except I was interested in price Vs performance...Compared to jupiter HT in this part of this circuit..Well yes different..for the price you have got to try these 😀
Switched on Jessie J and goose bumps..LOL
So as it stands now for a laugh orange drop to Op tubes and as above..LOL
The saga continues...
M. Gregg
M. Gregg
- Tubes / Valves
- Vacuum Tube OTL power amp!!
