900W H-class PA Amp with Limiter
balanced input bx500
TEF H900
Follow schematic with darlington BD681 and 10k preset for biasing, and I suggest balanced input like in BX500 with volume pot.
___
Hi Apex audio
greetings any particular reason for using BD681 AND balanced input
like BX500 in TEF H900 and is it safe at 70 and 120 volt dc supply rails please
what will be power in 4 ohms and 2 ohms load thinking of making it
warm regards
andrew lebon
___
Hi Apex audio
warm regards
andrew lebon
I not suggest to use 2 ohms with 4 pairs, on 4 ohms 1200W is maximum power.
H900 TEF TRIAL DRIVER PCB
Dear Sir Apexaudio
hello i have designed TEF driver pcb as you told me
1 Q5 is now BD681 instead of mje 340
2 R22 is 15K
3 R23 is 7.5K
input is balanced following BX500 schematic is it ok now or do i have to do any more changes have 8 output pairs LV is 70 volts dc HV 120 DC are these voltages safe please
can you help me
thanking you
sameerx1
Dear Sir Apexaudio
2 R22 is 15K
3 R23 is 7.5K
can you help me
You have some mistakes on your pcb on balance input layout routing.
thanking you
sameerx1
