jbl gto804 tapped horn/ folded horn
Well there is no free lunch. I think 2 in ~71l is OK considering you have a 50l box?
Code:
ID=28.80
Ang=2.0 x Pi
Eg=2.83
Rg=0.00
Fta=-0.29
S1=275.00
S2=270.13
Par=19.50
F12=0.00
S2=270.13
S3=205.24
Par=260.00
F23=0.00
S3=205.24
S4=200.00
Par=21.00
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=214.00
Bl=12.89
Cms=2.51E-04
Rms=3.36
Mmd=113.38
Le=1.64
Re=3.49
TH=2S
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lpt=0.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=5.0
Comment=NEW RECORD - JBL GTO804
I would NOT design for ED drivers, they are not the specs they claim; I have measured TSP's for both versions of the 18" and they are not even close. When I contacted ED the excuse they gave me was they don't have the ability to measure drivers...
+1 on that. I've measured the 13kv and the 13Ov - nowhere near measured specs. Looks like they gave you a different excuse than they gave me. See http://forum.edesignaudio.com/showthread.php/13kv-2-d4-questions-55280p2.html
Compact - Lower - High Power
I always liked the sound of a good 8"; compact is nice also. As far as goals: lower; I don't need to play it loud, although HT action scenes (explosions)can bottom-out, ruin a driver, so want to keep that in mind.
Yes, Doug here.
Hi Doug,
What direction do you want to go - lower, louder, fatter response???
I've made room in my inbox😛
when i play movies, i run 2.1 stereo
i have a denon pma710ae stereo amplifier with q acoustics 2020 speaker in gloss black and my 500 watt power amplifier, i never bottom the subs out even in movie scenes, but i mainly listen to dubstep, drum and bass with lots of lows and a sinle 8" in a room my size is ample, two just rumbles the floor and everything else around me
Hi 2009thread1,
Do you have any idea on a preferred size? When I simulate a TH (for a single JBL GTO804D) in Hornresp I get something around 95/110 L_net. For a tapped horn with a long folded horn path that may mean 125/130 L_gross. Your preferred external size will determine the folding.
Hi 2009thread1,
I haven't found time (or reason, I use ACAD) to learn Google sketchup, maybe NEO Dan can help. I'll attach a first try Hornresp input and spl window:
P2D28 8"
Just had thought, I have a couple of these unused.
Rockford Fosgate
Fs (Hz): 40.0
Re (Ohms): 3.50
Le (mH): 2.5
Qts: 0.45
Qes: 0.48
Qms: 6.00
Cms (m/N): 0.18
Vas (L): 10.0
Mms (g): 88.5
Mmd (g): 86.9
Rms (kg/s): 3.7
Airload (g): 1.6
SPL (dB - 1W/1M): 84.0
BL (T*M): 13.0
Woofer Displacement: 0.85 0.030 liters | cubic ft
Power Rating: 200 400 RMS | Peak
Linear Excursion, pk-pk (Xmax): 0.315 8.0 inches | mm
Sd (cm2): 200
Rockford Fosgate
i live in the uk so buying from america will be expensive, how would the rockford fosgates hold out on 250 watts rms ?
The sketchup TL looks like 72.38 L_gross, that is a lot smaller. But which one is better? 🙂
ive never heard a t-line before, but from videos they're really loud on the lows, but ive never heard an 8" tapped horn before
Hi 2009thread1,
🙄 Don't be looking at me - your the one with AutoCAD :snooty:
It's not like you need AutoCAD to get good looking output either:
Go have a look and VOTE
