Federmanns thread, and pictures, can be found in Vendor's Bazaar
http://www.diyaudio.com/forums/vendors-bazaar/176365-mosfet-amp-5-pairs-irfp240-9240-a-12.html
moderation
moderation
My attempt to make the amplifier.
Nice attempt, successful?
Sound worthy.
Please, can you post more info, and with what speakers?
dear lanchile,
happy neww year,can you send me this pcb copper side picture.thanks
your sins,ly masood
your sins,ly masood
So! cabinet is pretty much done. I need to make another shelf and a drawer. The top rack unit has pull out lights! Both of the Crown amps are modified by me (bigger filter caps, different op amp, signal capacitor swaps, etc.)
Now I need some speakers to go with this...
wood work looks perfect .... though your amps are a concern ...way too old. I hope you been working on them .
Gents,
Sakis is a dentist, a pyromaniac, a peeping tom, and a junkie.
Thanks Jacco - I needed that laugh today... 😛
Well, they may be old designs but they are the same as the new ones from Crown. I changed the opamps and several other things.
Oh, and thanks but the wood work is not perfect. Of course, I see all the flaws...
dear lanchile,
your sins,ly masood
2sk1058 2sk2221 irfp9240 mosfet amplifier schematic
I'm making progress on my chip amp. I got to use my new drill press for the first time. I can finally make nice holes in sheet metal now. I installed 2 rivet nuts in M6 size for the transformers. It just so happened that they bolts they provided are also M6. I didn't plan that! wow. Anyway, I'm using the rivet nuts "backwards" so nothing pokes out of the box. There's a Twisted Pear USB receiver DAC in the center, with the Audio Sector LM3875 amps.
What side of the panel is the threaded fastener?rivet nuts backwards
What carries the bolt tension into the panel?
How strong is the squishy aluminium that the rivet is made from?
- Post your Solid State pics here
