How is the surface of the original disc? Does it play other originals?
The original disc surface is perfect as far as i can see. Yes it does play other original discs but i find it is very fussy with discs ie producing this whirling static noise on a lot of discs.
Quan
I'd dismantle the mech and give the laser a good clean inside and out. It may help. Its a bit of a fiddle but it could be as simple as needing a clean.
Clean the metal guide bar and run a cotton swab doused in IPA over the lens.
Ok thanks but i will stick to medical grade alcohol solutions.
Quan.
Lmao!!!
And for those who are completely confused...........IPA Isopropyl alcohol
Although a pint of medical grade pale ale might work as well. Can't say for sure as I've never tried!!! 😉 cheers!!!! hic!
Just when I thought this thread couldn't get any better, it covers beer now too?!
Broke my player yesterday somehow. No display and disc spins uncontrollably. Spent hours going over the PCB looking for faults but had to sleep on it. I'm about to try again. Wish me luck.
Good luck !
never fear.... it will be sorted on the end
Lmao!!!
LMAO, definitely medical grade for sure-cheap and cheerful- 99 percent alcohol not the weaker Whisky type.
Thanks Ricardo. I hope so.
So I tracked down the cause of the disc spinning wildly. It was a broken trace on the digital power supply to the decoder.
I still have no display. The disc tries to read repeatedly but fails. The +/-12v rails are fine, but there's a very low voltage into Q851 (less than 1v).
Edit: Hmm.. . only seeing 4v AC into U311, U312. That's wrong, isn't it?
Edit again: Oh no, sorry, it is right. Doop-de-do...
Calling it a day. Current status:
- No display
- Disc repeatedly spins one way, then the other, then stops.
- Sled moves correctly in service modes, but disc spins like a circular saw on a later mode.
- Tiny voltage going into Q851 (can't remember if it was negative).
- CPU, DAC and op-amps seem fine.
- No display
Check the clock. Lack of it can cause the disc to spin very fast.
It does sound like there could be some fracture on the board in the psu area as the display is completely isolated from the rest. I would start checking supply rail voltages everywhere!
Ben, I'm not sure if I've got this 100% right but it won't take long to try this...
Unplug the front panel ribbon and turn the player on, see if it plays the disc. I think this step is a sure-fire way to test if the front panel ribbon is working or not.
I don't suspect the ribbon because the display and disc reading failed at the same time. The only difference without the ribbon plugged in is the controls don't work. It tries and fails to play in both cases. The CPU is apparently working because the service mode controls work, but the disc is behaving strangely and it can't start playing the disc. Anyone know what no power into Q851 would mean?
Not to worry, at least you've ruled the ribbon out (which could have caused those symptoms). Q851 is the -18V regulator which is for the display. No voltage here probably means the zener diode next to it has failed, or the reg itself, or (most likely I think) the preceding PSU has failed. Most likely, given yours is a KI, the transformer secondary winding that feeds this has been pulled off the PCB. Have you checked the transformer?
Look on page 14 of the PDF service manual and you'll see what DC voltage and AC voltages precede that regulator. Check these voltages.
Interesting. Well, the green wire (U305) did unfortunately break off, and it seems to be made of some sort of enchanted solder-proof wire. I thought it was conducting but I'll have to check again. I presume that's it, 12.7v. I found it tricky to follow the trace with all the diodes and omitted parts around that area.
Measured so far:
u305: 14vac
u306: 16.6vac
u307: 16.6vac
u308: 10vac
u310: 10vac
u311/12: 3.9vac
u267: 14.3vac
Measured so far:
u305: 14vac
u306: 16.6vac
u307: 16.6vac
u308: 10vac
u310: 10vac
u311/12: 3.9vac
u267: 14.3vac
- Digital Source
- Marantz CD63 & CD67 mods list
