Simplistic mosFET HV Shunt Regs
Seems to me all the current drawn is 12mA and the circuit behaved correctly in that although you increased the idle current the current drawn by the circuit+load did not change. You got 280-131 = 149V across the series mosfet, you better have some serious heat sink while testing, in case the current goes up by whatever reason.
If you want higher Vout then higher value R4 should work. While keeping R8 fix measure the voltage across R4 to figure out the current, then calculate a new suitable R4.
If you're using a 2sk170bl, using R8=300R should give you about a 1mA current going through R4. An R4 of about 240k should put you in the ballpark Vout of 240V. Then you can do some small adjustments of R8 WHILE THE VOLTAGE IS OFF and measure again.
