Which Are Best Budget Compression (mid-h.f. range) Drivers?
Hello Mr Maestro. I am on the road of building a horn loaded loudspeaker system. I think we can colaborate.
I am building my own horns bdw. I will try my luck with a large format CD, and a big tractrix horn(70 cm diameter). The cheapest driver that can cover most of the mids is Monacor KU-516. 160 to 6500 Hz. It is not an ultimate solution but it is a good start. Sound quality is still a mistery.
Someone from Poland measured it, and the results were good(linear response).
The CD *might* be a copy of an old high end driver.
hello rvrazvan,I can even wait to colaborate....we'll talk on the phone anyway...I can give you some advices on papier-mache tractrix horn buildings,I've build my own pair-about 70-80 cm diameter after the Inlow method...there are tar damped,there are some subtle technical details which I want to discust with you...now I have a pair of 15 multicellular horn(about 300 Hz)...
YES"we do not want to introduce any harmonic behavior"but the REAL FACT IS THAT THESE HARMONICS AND TONAL CHARACTER OF SOUND ARE PRESENT IN THE ECUATION...WE DON'T HAVE AN DRIVER-TRANSDUCER WITHOUT CABINET SUSPENDED IN SPACE AND EVEN IF WE'LL HAVE ONE THE.........
Maestro
:nownow:
apart from being hard to read, that writing style with capital letters is considered shouting
please dont
:cop:
moderation
Sorry,sorry,sorry!!!Please understand evreybody,I was just use that caracters to lay emphasis(professional flaw I guess-I'm an visual artist)on my ideas-concepts.....not shouting,but it's good for me to know from now on...I'll abdicate from capital letters.Thanks!!!
Hi maestro,
I use a simple made glasfiber horn not extreme thick. This combination sounds warm indeed, not only in my ears also from others who listened. The reason good subbas extension to 20Hz very nice flat response of the 2" driver horn combo. Quality attenuation and use of good mkp capacitors.
You can use wood if you like and think that is the way you want to shape the sound.
horn response 0-15-30-45-60-90
Nice that you show us what you got there...on low fr.(2 woofers) do you have an closed cabinet??
2 X 15" woofers on a openbaffle who play -3dB 30Hz 94dB 1wmtr average. After building this a came to understand that a OB does the best job dealing with room reflections or uses room reflections.
The rear wall reflection helps to extend the response down to 20Hz. with out it the -3dB point would be 40Hz. And you have a compact high efficient system even females aren't totally against it.
Now I've supposed that it could be an OB but I've seen the front panel so narrow...but the rear wall helps of course....yes I know about the way that OB deal with reflections,anyway you have a low sound that is spacial,have good atack and decay and is free from box colorations and other distorsions implied in this...me personally,I've choose the horn route for midbass(piramidal 50 mm spruce horn) down to 70 HZ-with a 15'' woofer...I've just finishing my system so these days I'll put everything in it's place and start the game...I'll post one photo with the system...
The nearrow baffle is needed to get flat response at higher frequency above 600Hz.
I did backloaded horns the last 2010 102dB 1Wmtr it did even 45Hz. Stil not good enough its better to have response down to 30Hz then high efficiency IMO.http://www.diyaudio.com/forums/multi-way/170024-project-presentation-horn-almighty.html
When you use two of these 18" you will have efficiency and real subbas and the same behavior as a closed box low group delay.
http://www.eminence.com/pdf/Omega_Pro_18C.pdf
It will be easier to use a cone to 800-1000Hz and cover the rest with one horn.
A three way tappedhorn sub - middriver 6-8" - 1" HF.
That's my conclusion as well. A 12" driver is generally pistonic up to about 1200Hz and there are plenty of 1" CD's with horns that will extend down to 1kHz or so. For the subterranean frequencies I plan on installing a 12" self powered sub in each cabinet. So, two 12" drivers and one good sized horn should be plenty good for me, all active crossovers of course. My plan is to have overall system sensitivity of about 100dB/w.
Looks cool your horns.
You only have to build a tappedhorn sub woofer. Looks like you are in spired by Volvotreter. He also uses tappedhorn subwoofers.
For that you choose a driver with low Fs and big xmax and small Vas. Like car subwoofers. These make a great tapped horn.
A suggestion from my side Mivoc AW3000 great sub for tapped horn 50 euro.
Nice! You are a long way ahead of me.
I have used inlow's site as an inspiration source also, for the tractrix horn.
Hope to have it ready until the end of the spring 😀.
The bass horns have the drivers in? How do they sound compared to normal bass enclosures?
Helmuth thanks!Yes indeed,I was inpired by Volvotreter...thanks for the tapped horn driver sugestion.
Maestro also thanks you inspired me to to think about the conical lowmid horn.
The speaker of my first karlson loudspeaker project made 1990. I still own the driver it is perfect suited. It is the BGS25NG, did a simulation it looks very promising.
It would make my system 10-15dB louder I use a 12W PSE hybrid tube amp. It would make a 115-120dB system ground shaking loud.
