selenium d405 phenolic driver + selenium d220ti my bet with wood round horns
more horns:HORNS - HiFi Chile - Página 74
Bump...any comments on the P.Audio BM-D26S for ~$30?
http://www.paudiothailand.com/showproduct.cfm?id=670
http://www.usspeaker.com/paudio bmd26s-1.htm
My experince with P-Audio is that their data sheets are pure fiction. Real measurements show a completely different product. Usable if you measure the ones that you have, and that works for you, but not usable if you are relying on the spec sheets.
P.Audio System Co., LTD
P.Audio BMD26S - P.Audio BMD26S 1" high frequency driver. P.Audio BMD26S speaker components available at US Speaker.
Haven't heard too many compression drivers for under $100 that I could live with. I recently bought one of the $50 Celestions CDX1-1445s, based on prior experiences with the CDX1-1425, which was a steal at $35. (it's $100 these days, due to the cost of neodymium)
Bill Waslo has posted some measurements of the 1445 here (http://www.diysoundgroup.com/forum/index.php?PHPSESSID=3e7f1c325dae97f639a00cf2d1fd9e8e&topic=19.15). Augerpro has posted measurements of the CDX1-1425, and I have too.
@ Patrick
try these two
Eminence apt 50 and......Selenium d 250 x!
Huge value for the price.
Also phenolic.....not titanium
try these two
I would recommend
Denovo DNA-150(~2khz+)
Celestion 1445 (~2khz+)
Radian 475PB (~1.6khz+)
BMS 4550 (~1.2khz+)
Denovo DNA-350(~1khz+)
Denovo DNA-360 (~1khz+
Denovo BA-750 (~700hz+)
BMS 4550 (~1.2khz+)
Has anybody tried the new cd from Faital Pro? HF-107.
FaitalPRO - Professional Loudspeakers Made in Italy
I looks good on paper with its 1000hz-20 000hz xo.
well since good horn systems cost around $70-150K in ready to go state , budget in $7-$15k for Diy or don't bother .This is my current take on the subject. Rgrds, L
well...we start with 1000$ and move from there. 😀
Has any one tried the JBL 2452H? What is a suitable horn for the 2452h?
My horn system cost nothing like $7K
Phil
Phil
I suggest FaitalPro HF100, and build your own waveguide
done right it could beat even the top budgets
diy budget for two, 150USD 😀
Agree. (I've been coveting those HF100 as tweeters). I put together my Altec VOTT system for much less than $7K. I don't think you'd have to spend that much retail for new parts on a good horn system
See here:
http://www.diyaudio.com/forums/multi-way/100392-beyond-ariel-809.html#post3166396
If you DIY and choose carefully, it does not have to cost a fortune.
See here:
And oddly, the matching horns cost just as much! I think I'll make a pair of small diy multi-cell horns for them.
Trying the JBL 2452 on 2380 with 1.5 inch throat entry, sounds great to me.
The horns cost $15.00 plus freight had to buy 10 to get this price. also trying the the 2380 2 inch throat with the JBL 2446.
Phil
Phil
Driver
Hi All:
I like try a 3 way system with 2 eminence 15A in OB + selenium d250X in mid range.
What would be best (cheap) driver in the 5-20kHz range in this configuration?
Thanks in advance
Alberto.
Hi All:
Thanks in advance
Alberto.
- Which Are Best Budget Compression (mid-h.f. range) Drivers?
